Author Topic: [IC]MW-Unmanned playground無人樂園|11/03 Nov kit & lamp kit updated  (Read 26656 times)
Offline York Chan
https://forms.gle/5wB1qPC4fLm7xuUM6
The inspiration comes from the unmanned water park, using a segmentation method similar to the slide, and the color scheme is also derived from the pool core slide. The novel key part also uses the pool core elements such as the infinite loop arch, smiley balloons, various loop stairs, etc.
Info
Manufacturer: Milkyway
Material: ABS(outside)+PBT(inside)
Production Method: Double injection + Part of novelty kit are UV printing
Profile: Cherry profile
Sample
Renders
Deskmat
Kitting
Updates
2025/11/03: Due to manufacturing process constraints, the areas highlighted in green on the nov kit will use UV printing, while the rest will be manufactured using two-shot molding.
As for the lamp kit, the transparent parts have been changed to white. If customers are not satisfied with this modification, we support refunds.
2025/09/12: Hiragana kit fixed R3 ‘|\’ to pink
2025/09/02:Add hiragana kit;
2025/07/28:Add 6 UV-printed inside keys for Base;R1 pgdn & end form Base kit changed to Numpad kit;
2025/06/01:New 40s kit;
2025/06/01:Confirmed samples. Rendering adjusted based on color samples;
2025/06/25:Add deskmat;
Vendors
CA-Unikeys(Pre-sale)
AU-Torokeeb(Pre-sale)
SG-Qwertyqop(Pre-sale)
UK-Prototypist(Pre-sale)
EU-Coffeekeys(Pre-sale)
KR-Swagkeys(Pre-sale)
US-Divinikeys(Pre-sale)
CH-zFrontier
JP-Yushakobo
DE-Candykey
Contact
Material Lab:
E-mail: 15813785718@qq.com
QQ group: 325624355
Instagram: https://www.instagram.com/yorkchan3/
Discord: https://discord.gg/RFaeWD3BN8
Milkyway:
Discord: https://discord.gg/ecxzfnue5P
Instagram: https://www.instagram.com/milkywaykeys/
If you are interested in this setting , you can copy this code into your signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=125160.0][img width=302 height=120]https://i.imgur.com/MrmfGP4.png[/img][/url]
« Last Edit: Mon, 03 November 2025, 02:11:29 by York Chan »
Offline keepoto
  • HHKB top for TKL pls
Re: [IC]MW-Unmanned playground無人樂園
« Reply #1 on: Mon, 12 May 2025, 05:20:18 »
exciting gameplay
Offline Manukbs_
« Reply #2 on: Mon, 12 May 2025, 06:16:32 »
It would have been perfect if instead of translucent it was glossy effect, other than that, it's an incredible design, gl
Offline örange_stone
  • No fancy life But fancy keyboard
« Reply #3 on: Mon, 12 May 2025, 08:28:37 »
Fun concept, and I will say it's nice that the novelties are under supervision. I will be thinking about it all the time ;D ;D
Offline York Chan
« Reply #4 on: Mon, 12 May 2025, 09:43:46 »
Maybe my expression is wrong, but I am currently adjusting my cooperation with suppliers and cannot make it public for the time being. This is really embarrassing. :-X
Offline MisterBananaRat
« Reply #5 on: Tue, 03 June 2025, 16:54:49 »
Very Nice
Offline DivinaPapaya
« Reply #6 on: Wed, 04 June 2025, 07:51:43 »
I am getting one 100%. Looks gorgeous. Excited to see how the novelties will look. GL
Offline York Chan
« Reply #7 on: Tue, 17 June 2025, 21:59:30 »
The rendering of the keyboard has been shown as much as possible. :thumb:
Offline York Chan
Re: [IC]MW-Unmanned playground無人樂園|Looking for vendors
« Reply #8 on: Thu, 04 September 2025, 21:02:16 »
Expected to run in October. We are currently looking for vendors. If you are interested, please contact us. :thumb:
Offline tigerali
« Reply #9 on: Thu, 04 September 2025, 22:30:06 »
Great news!
Offline York Chan
Re: [IC]MW-Unmanned playground無人樂園|9/20 Vendors update
« Reply #10 on: Fri, 19 September 2025, 21:50:09 »
9/20 Vendors update :thumb:
Offline BossKeebs
« Reply #11 on: Sun, 28 September 2025, 04:38:07 »
those are some sweet looking keycaps right there
Offline Nevrest
« Reply #12 on: Mon, 29 September 2025, 18:45:09 »
Love the pastel colours!
Offline York Chan
Re: [IC]MW-Unmanned playground無人樂園|11/03 Nov kit & lamp kit updated
« Reply #13 on: Mon, 03 November 2025, 02:06:49 »
Updates
2025/11/03:Regarding the MW Unmanned Playground project, let me share the latest updates. Due to manufacturing process constraints, the areas highlighted in green on the nov kit will use UV printing, while the rest will be manufactured using two-shot molding.
