Author Topic: Should I buy that monitor*?  (Read 11284 times)
Offline sam113101
« on: Wed, 03 November 2010, 22:36:39 »
http://www.circuitcity.com/applications/searchtools/item-details.asp?EdpNo=4938558&SRCCODE=NEXCC&cm_mmc_o=2mHCjCWw0fzTCjCVqHCjCdwwp&cpncode=22-85633449-2
It's the cheapest 1920x1200 monitor I've found, and I really need that resolution. Anybody ever heard of that brand*?
I'd need two of them. I'll buy only if they're not crappy monitors.
Hoping to hear from you again, your dearest friend, sam113101.
Offline D-EJ915
« Reply #1 on: Wed, 03 November 2010, 23:03:01 »
It's probably not better or worse than any other low-end monitor to be honest, all the products in that price range use the same electronics.
Offline Arc'xer
« Reply #2 on: Wed, 03 November 2010, 23:56:09 »
If your willing to wait for a U2410 to pop around with a good bargain coupon then it would be a much better buy. I'm pretty sure the I-inc is a TN panel and if your wanting 1200P, I'm guessing you also want a monitor that provides better quality with the U2410 being IPS.
For some reasons the U2410s really spiked in price. Saw a few weeks back some of them going for nearly 250 dollars with coupons and savings.
There's a few other 1200P monitors most of them have the premium attached to them but once in a while they pop up with coupons so you never know.
Offline Fwiffo
« Reply #3 on: Thu, 04 November 2010, 00:19:51 »
Seems weird that it's a 27.5". 1920x1200 is a resolution I associate with 24" monitors. So I'd consider the extra desk space consumed and coarse pixel pitch to be pretty big negatives. For that much desk space you could have a 2560x1440 Dell U2711 (though that's obviously a radically different price class).
You can call me... Keyboard Otaku... or not quite...
Offline Hak Foo
  • Make America Clicky Again!
« Reply #4 on: Thu, 04 November 2010, 00:32:33 »
160 degree viewing angle = TN panel.
Look for a secondhand 24 with a known better panel, maybe, or if you can swing the lower res, get the Dell 22 with the good panel for the same money.
I want one of those for work, but the boss is sure to get me $129 TNs.
Overton130, Box Pale Blues.
Offline WhiteRice
« Reply #5 on: Thu, 04 November 2010, 00:44:11 »
For ~$250 get yourself a Samsung 22"
Offline chongyixiong
« Reply #6 on: Thu, 04 November 2010, 02:04:52 »
Why not 2 U2311Hs?
1920x1080 and if you're doing portrait for both of them.. the 1080 is pretty adequate
Offline instantkamera
« Reply #7 on: Thu, 04 November 2010, 06:07:07 »
Quote from: chongyixiong;242420
Why not 2 U2311Hs?
indeed.
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
« Reply #8 on: Thu, 04 November 2010, 09:34:36 »
Quote from: instantkamera;242444
indeed.
And it's pretty cheap and colours are MUCH better than TN panels.. I don't know why people are buying them and complaining of tinting issues when the general case is that no one seems to know what it is about.
Instead, most users who jump onto the IPS bandwagon begin to VISUALIZE and FEAR of the tinting problem before even getting the monitor and enjoying it.
PS: U2311Hs are about RM659 here in Malaysia so I think the US can do better in terms of pricing.
Definitely fits your budget btw.
Offline Ekaros
« Reply #9 on: Thu, 04 November 2010, 09:52:57 »
I prefer 16:10 over 16:9, but if you want to get cheap...
Good monitors are like mechanical keyboards and bad ones like membranes... Monitor is most important output device you have, no sense getting bad one...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline zefrer
« Reply #10 on: Thu, 04 November 2010, 10:02:46 »
16:9 on a PC monitor is one of my pet peeves. More screen real estate = good no?
Offline Fwiffo
« Reply #11 on: Thu, 04 November 2010, 10:26:52 »
It's irritating that 16:10 tends to be so much more expensive than 16:9. For example, compare these otherwise very similar Dell monitors:
Dell UltraSharp U3011, 2560x1600 - $1499
Dell UltraSharp U2711, 2560x1440 - $999
Dell UltraSharp U2410, 1920x1200 - $599
Dell UltraSharp U2211H, 1920x1080 - $249
That's at extra 50% or 140% more for an extra 11% of screen real-estate!
Offline zefrer
« Reply #12 on: Thu, 04 November 2010, 10:33:40 »
Yup. Don't get me started on 16:10, 120hz LCDs (there aren't any..)
Offline Will
« Reply #13 on: Thu, 04 November 2010, 12:56:40 »
Quote from: zefrer;242516
Yes there are, Viewsonic and Samsung both have 1680x1050 120hz LCDs. I kind of regret selling mine last March and really want to buy another.
Offline zefrer
« Reply #14 on: Thu, 04 November 2010, 13:30:33 »
You're right, I meant 1920x1200 ones. @OP, you'll get what you pay for - not much.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #15 on: Thu, 04 November 2010, 13:57:15 »
Quote from: zefrer;242588
That equally applies to the areas that one doesn't see immediately, like long-term reliability or EMI suppression. Low-quality electrolytics in the power supply or badly designed CCFL inverter = trouble. All been seen in cheap LCDs.
Offline zefrer
« Reply #16 on: Thu, 04 November 2010, 14:50:15 »
Exactly. I used to buy a different brand (than OP) of low cost LCDs and both that I had stopped working properly within 2 years. One got dimmer and dimmer, the other stopped working entirely.
Offline Arc'xer
« Reply #17 on: Thu, 04 November 2010, 15:24:55 »
OP, there's also have the dell SP2309W while it's a TN panel it does have a resolution of 2048x1152, while a strange resolution it's the 16:9 of 2048x1536 if your wanting more vertical space it's a more acceptable compromise of vertical space if you can't find a 1200P monitor and not wanting 1080P. But you do lose the divisional resolution(of 1200P)if your working on lower resolutions or gaming on lower resolutions depending on what your doing like say 1600x1200 or 800x600.
Even a coupon code for it till the Nov 7th going for 200 rather than it's usual I think 250-300+.
« Last Edit: Thu, 04 November 2010, 15:36:53 by Arc'xer »
Offline a_fluffy_kitten
« Reply #18 on: Thu, 04 November 2010, 18:34:45 »
Quote from: sam113101;242363
Well, the fact that it is not only a brand no one has ever heard of but is also extremely cheap is a very good sign.
The rational conclusion would be that this is an extremely good monitor.
2x Filco Blue Tenkeyless (and boy are they nice)
Offline sam113101
« Reply #19 on: Thu, 04 November 2010, 18:42:39 »
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #20 on: Thu, 04 November 2010, 18:46:53 »
Well, if you got a big, sturdy, table with lots of room you could always go with CRT's. You could get a 21" CRT monitor capable of displaying 1600x1200 at 100Hz for pretty cheap (a Trinitron from the mid 2000's). They get great color, and have very even black. But the problem with nice, big CRT's is that, well, they're big. They're heavy too. So make sure you have a lot of room if you want to go that way.
But, if you're not into big, heavy monitors, I would recommend looking into used LCD's, or holiday sales at stores. A relative of mine picked up a new 24" Samsung LCD that displayed 1900x1200 that was on sale at Wal-Mart for a little over $120 when it was on sale.
Offline Ekaros
« Reply #21 on: Thu, 04 November 2010, 18:49:08 »
Quote from: sam113101;242684
What about that*?
http://www.bestdirect.ca/products/218560/Samsung/LS24MYKRBQA_ZC/
Cheap, but limited, TN-panel nothing fancy...
[SIGPIC][/SIGPIC]
« Reply #22 on: Thu, 04 November 2010, 18:54:05 »
Here's an LCD that oughta do it. $150
Offline Brodie337
« Reply #23 on: Thu, 04 November 2010, 19:48:59 »
In my experience, about 26 inches is the biggest I'd want to go at 1920x1200. Anything bigger than that looks like ass to me.
For the record, I've got the Asus VK266H, a 26 incher. Not a bad monitor for a TN, but there is a little light leakage.
Offline zefrer
« Reply #24 on: Fri, 05 November 2010, 08:14:30 »
What about that*?
Decent quality for a TN based LCD. I have the 26" version of it. Good value for money I think.
Offline imagine7xy
« Reply #25 on: Fri, 05 November 2010, 19:55:42 »
I would recommend (1080p good quality, cheap price, with 100x100 VESA mounts):
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009266
If you get 2x then get:
http://www.amazon.com/gp/product/B002R9HQLI/ref=oss_product
1080p is a very standardized resolution, 23" is a great DPI for it as well.
« Last Edit: Fri, 05 November 2010, 19:58:27 by imagine7xy »
« Reply #26 on: Fri, 05 November 2010, 21:28:39 »
Quote from: Ekaros;242498
Ditto, I also prefered 16:10 over 16:9.. that was the exact reason why I sold 2 of the U2311Hs and bought a U2410 instead. (And I plan to buy another U2410 when the price really drops)
TS, you never did mention whether you would like this both to be used in the horizontal or vertical position.. if for horizontal, I guess you could do better with a 16:10 resolution, or maybe a 4:3 - but the last available of such commercially available IPS monitor is the Dell 2007FP.
Else, the U2311H works extremely well in portrait mode and due to its much-better vertical viewing angles, you don't have to worry about not seeing the monitor properly (when placed at an angle). Normal TN monitors can't beat those IPS for vertical viewing angles!
Offline imagine7xy
« Reply #27 on: Fri, 05 November 2010, 23:46:52 »
I wouldn't buy WUXGA right now because of the cost even though I actually prefer it over 1920x1080 for actual computing. I am not exactly sure why but the 1920x1200 average nearly twice the cost, and 1080p monitors are 5-6x more popular, definitely the bestselling by a long shot right now.
« Reply #28 on: Sat, 06 November 2010, 06:16:57 »
Quote from: imagine7xy;243280
No idea why either.. I got the U2410 with some change after I sold off my 2 U2311Hs.. it's ridiculously expensive to maintain the 16:10 format man!
Offline Ekaros
« Reply #29 on: Sat, 06 November 2010, 11:50:37 »
It's mainly due market, 16:9 are smaller, cheaper to make, and they can be used on normal TVs too I think. And customers don't know difference between fullHD and more than fullHD and can't ask for it. Mainly problem is that people don't ask more, it's pretty small group which reguest something like 16:10, I think those are more for entreprice-sector than consumer.
Going to get 30" onces I get that 1-1,5k to spare...
[SIGPIC][/SIGPIC]
