Author Topic: [IC] Syrin TKL - An HHKB TKL?  (Read 10459 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Tue, 01 July 2025, 06:45:56 »
Interest Check Form
Syrin TKL
by Rien
Post edited by Click Clack
The design inspiration of this keyboard comes from "reeds" found in nature.
Introduction
We often see it by the lake or beside the river. Its branches stand upright upwards while its leaves hang downwards. When the wind blows, its posture is particularly beautiful. We believe this state is suitable to be displayed on the side of the keyboard.
Index
- Design
- Structure and Layout
- Specifications
- Colorways
- More Photos
- Pricing and Vendors
- Follow the development
Design
Due to the limitations of processing technology and production costs, we designed the sides of the keyboard as multiple small arcs, and protruded the lines at the junction points to present the elegance of reeds. At the same time, the rear end of the keyboard is designed with an open structure, creating a tall and upright posture like reeds.
The conventional way of handling keyboard weight distribution is to place the weight at the top, but this results in an unbalanced keyboard with a heavy top and a light bottom.
During the design phase, we aimed for visual harmony in the keyboard and to achieve a weight ratio of 50:50 for the upper and lower parts of the keyboard. Therefore, the weight was placed at the bottom of the keyboard's back.
By rotating the lines on the side, a "island" is formed at the bottom. Use rounded corners to smooth out the lines to make them resemble ripples of water.
We adopted a concealed screw design and used magnetic FPC, which made the keyboard more streamlined and reduced the assembly complexity.
Exploded View:
The fixation methods of the keyboard are GASKET and TOP.
Customize two types of silicone covers to enable the switching between GAS and TOP.
The FR4 diaphragms are isolated within the frame walls to ensure a smooth interior space for the keyboard, reduce sound rebound, and leave a gap to counteract the internal cavity sound.
PCB Layout:
Hot-swap
Solder:
Shell Layout:
HHKB:
WKL:
Component parts:
Shell (Shell, Weight, Sign plate)
PCB (mother board and magnet daughter board)
Pate (Alu/PC/FR4)
Poron
Silicone gasket
Other accessories
Specifications
Front Height: 17mm
Slope gradient: 8°
PCB: Hotswap or solder with VIA.
Colorways
Silver:
Ice Blue:
Dark Blue:
Lilac:
Pink:
Burgundy:
Weight Colors:
Brass (Heated Color):
Stainless Steel (PVD Silver):
Stainless Steel (Matte Silver):
Stainless Steel (Cut Marks):
More Photos
Pricing and Vendors
Group Buy Details
Time:TBD
Form:Open GB in Limited Time Window
Pricing:
Estimated Price:  $320-$330
Vendors:
- The USA and Rest of the world: Click Clack
- UK: ProtoTypist
- OCE: TORO
- EU: Keygem
- SEA: Ktechs
- CA: Unikeys
More will be updated.
Join ClickClack’s Discord for the latest updates, discussions, and questions:
Fill in Interest Check Form:
Follow ClickClack's IG for other new projects:
« Last Edit: Sun, 06 July 2025, 08:43:01 by ClickClack.io »
Offline DirtyGingy
Re: [IC] Syrin TKL - An HHKB TKL?
« Reply #1 on: Tue, 01 July 2025, 06:54:12 »
I'm a diehard winkey user, but this does look cool
Offline ivanh98
« Reply #2 on: Tue, 01 July 2025, 07:02:35 »
hhkb floodgates are opening for keepoto it seems. the back design with patina looks great!
Offline Sieglinde
« Reply #3 on: Wed, 02 July 2025, 11:48:03 »
HHKB looks really good.
Overall it would look much better if the front was kept clean and didn't have the little badge/LED.
Please consider that.
« Reply #4 on: Thu, 03 July 2025, 10:35:52 »
This looks really good
Offline Ruby437
« Reply #5 on: Thu, 03 July 2025, 13:31:19 »
The solder PCB looks like it doesn't support the HHKB (right winkey missing), is that an error or is HHKB only hotswap? That would suck since split right shift is solder only on your design.
Also would love to see 6u spacebar for true HHKB.
Offline Sm0k3d0uT
« Reply #6 on: Thu, 03 July 2025, 15:16:59 »
will you be able to order extra tops?
Offline Faraday
  • a toofpick changes everythang
« Reply #7 on: Thu, 03 July 2025, 21:18:06 »
ne 6u avail?
« Reply #8 on: Thu, 03 July 2025, 22:52:58 »
A real HHKB has a 1.75u right Shift, and a 6u Space Bar which allows the right Alt/Meta key to be in a position more accessibly by the thumb.
    • clickclack.io
« Reply #9 on: Sun, 06 July 2025, 08:43:32 »
The solder image has been updated to reflect the correct layout!
Offline omf
« Reply #10 on: Wed, 16 July 2025, 22:17:41 »
The problem with WKL is that it limits using it on Macs. Looks beautiful otherwise!
Offline tactilesbad
« Reply #11 on: Thu, 17 July 2025, 07:37:05 »
not really, no
Offline Livid
« Reply #12 on: Thu, 17 July 2025, 11:29:54 »
PCB layout shows WK option but shell layout doesn't, will it support WK or no?
