Author Topic: [IC] KAP Konpeito  (Read 4414 times)
Offline Sharkeys
    • Sharkeys
[IC] KAP Konpeito
« on: Thu, 03 July 2025, 20:57:45 »
Konpeito
Introduction
Hello friends!  My name is Sharkeys and I am pretty new to the keyboard design world!  Some of you may recognize me from the keygeek POMkin switch.  This is my first step into the keycap designing world after designing the POMkin switch.  I have definitely learned a lot!   Konpeito is inspired by the soot sprites, from the wonderful world of Studio Ghibli, and their sugar star candies they love!  It is supposed to give off the vibes of soot sprites carrying konpeito.  This set will be manufactured by Keyreative using their new KAP legend system and hybrid dye-sub double-shot method.
Kitting
The base kit should cover most layouts including UK and some 40s support, however I am up for adding more kits if the desire is there!
With the novelty kit I tried to keep it simple while still paying homage to soot sprites
Renders
Renders may differ slightly from actual product, but will try to color match as exact as possible!  These were also all done by me and my very limited blender knowledge!  I will work on getting some more renders soon.
Glare TKL by Geonworks
W1AT by Geonworks
F1-8X by Geonworks
Vendors
US/CA: Unikeyboards
UK: proto[Typist]
EU: CoffeeKeys
OCE: TORO studio
CN: Zfrontier
SG: Ktechs
Please fill out the IC form linked at the top!  Thank you for checking out my keycap design and your support as always!  I look forward to hearing your feedback and seeing what you all think of this set.
« Last Edit: Wed, 16 July 2025, 19:36:49 by Sharkeys »
Re: [IC] KAP Konpeito
« Reply #1 on: Tue, 08 July 2025, 14:22:30 »
Approval :thumb:
Offline Sharkeys
    • Sharkeys
« Reply #2 on: Wed, 09 July 2025, 17:50:19 »
Reserved  :p
