Author Topic: Topre Realforce numpad key acting wonky  (Read 6862 times)
Offline zslane
« on: Fri, 11 July 2025, 10:46:23 »
I'm seeking repair suggestions from the Topre experts out there.
The "." numpad key on my Topre Realforce RGB board is sending out the two-character string ".+" whenever I press it.
What could be causing this, and how might I fix it?
Offline Tactile
Re: Topre Realforce numpad key acting wonky
« Reply #1 on: Fri, 11 July 2025, 12:57:47 »
Does playing with the APC make a difference?
REΛLFORCE
Offline zslane
« Reply #2 on: Fri, 11 July 2025, 18:58:04 »
Yes, and not in a good way. When the APC is set to "green" (my default mode), all the keys work except numpad "." which sends ".+" as mentioned.
When APC is set to "red", the numpad "." only sends "." but then it is hard to produce a space with the spacebar.
When APC is is set to "blue", keys will register all on their own randomly.
