Author Topic: [IC] 825 - a simple 1800 office keyboard (EU/NA/Asia/AU vendors added)  (Read 13206 times)
Offline yz
825
a simple 1800 office board designed for the 8-to-5 grind
Contents
  • Specifications
  • Progress
  • Sales & Pricing
  • Renders & Photos
  • FAQ
  • Typing Tests
  • Socials & Build Vlog
1. Specifications
Case Angle:
Keyboard mount: Tadpole Top Mount
Front Height: 18mm
Effective Keyboard Height: 22.4mm
Net Weight: ~1.7kg (no internal weight, built)
Case Materials: 6063 Aluminium
Hardware Materials: SUS304 Stainless Steel (case screws & daughterboard screws)
Plate Materials: 6061 Aluminium & Polycarbonate (1.5mm thickness)
PCB:
  • 1.6mm FR4 designed by Zeix
  • QMK & VIAL Configurable
  • 3x LED indicators
  • Fly Daughterboard with ESD protection
Layout Options:
2. Progress
  • Keyboard – 2nd prototype built, external dimensions unchanged, added recesses for additional clearance, added a light blocker for LEDs
  • PCB – 1st prototype tested, adjusted tolerances and updated firmware
3. Sales & Pricing
Pre-order base kit price: SGD 385 (USD 295)
Extras base kit price: SGD 425 (USD 325)
PC/Alu plate: SGD 38 (USD 29)
Additional PCB: SGD 45.5 (USD 35)
Kit includes:
  • 1x Keyboard Case (hardware pre-assembled)
  • 1x Plate (Alu/PC)
  • 1x Solder-only PCB, daughterboard & JST cable
  • 4x 10mm bumpons
  • 1x Carrying Case
Limited GB (150 units)
FCFS on
Unikeys (NA)
PantheonKeys (Asia)
EloquentClicks (EU)
TORO Studio (AU)
Pre-order target date: Early-Jan 2025
Targeted Completion: Late-April 2026
4. Renders & Photos
Silver
Blue-Grey
Black
Warm Green
Prototype Photos
TBA
Exploded View
5. FAQ
  • Was this inspired by the cypher/hbcp/FC980?
    Yes.
  • Will _____ color/plate/layout be available?
    Nope. Plate files will be made public after fulfilment so feel free to have one made in whatever configuration you'd like.
  • Any vendors avail?
    Yes.
6. Typing Tests
Polycarbonate Plate with NK Cream Dreams (80a tadpoles)
Aluminium Plate with AEBoards Raeds R1 (80a tadpoles)
7. Socials & Build Vlog
To keep up with the latest information for this board, join my discord server, or follow me on instagram!
Thank you for checking this project out!
« Last Edit: Sun, 30 November 2025, 20:48:08 by yz »
Offline mr_foggy
  • neue = nope
Re: [IC] 925 - a simple 1800 office keyboard
« Reply #1 on: Sun, 13 July 2025, 07:21:36 »
everything about this is actually awesome. I’m very much in
Offline yz
« Reply #2 on: Sun, 13 July 2025, 08:08:08 »
cheers mate, appreciate it
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #3 on: Sun, 13 July 2025, 10:59:26 »
Very classic & clean design OP, I definitely dig it! The only thing I'd like to see is some internal weights to tighten up the sound some. Wouldn't even mind zinc weights to just add some extra mass to help dull out the higher pitches while still keeping the price reasonable at your 50 MOQ.
Offline Fluxius
« Reply #4 on: Sun, 13 July 2025, 13:14:25 »
Very nice. Will the 6u spacebar support be center, off-center or both?
Offline Raie_de_Boule
« Reply #5 on: Sun, 13 July 2025, 16:49:25 »
I'm potentially in  :-X
Offline yz
« Reply #6 on: Sun, 13 July 2025, 20:52:13 »
thank you. i'll be adding support for both
cheers
this was originally designed for my friends and relatives who wanted a custom keyboard that wasn't too heavy to bring around to-and-from the office, so I thought adding weights would kinda defeat that purpose. perhaps I could add some replaceable aluminium 'weights' and provide brass/stainless steel weights as optional extras
Offline yz
« Reply #7 on: Mon, 14 July 2025, 02:04:45 »
pending name change since there's an existing project by dnworks also called the 925 that I haven't come across until now  :-[
Offline Rob27shred
« Reply #8 on: Mon, 14 July 2025, 07:09:09 »
cheers
Ah, I see. I figured there must've been a reason you didn't have a weight designed into this. I'd be more than happy with having replaceable alum weights stock & denser material weights being add ons. Although since you have a prototype ordered already we'll get a chance to see how it sounds as it is designed right now. Never know it might be just fine as is without weights?
Offline yz
« Reply #9 on: Mon, 14 July 2025, 09:15:55 »
that'll be the first litmus test for sure, hoping for it to sound close to a cypher because that board sounds great without weights too
Offline Katumbas
Re: [IC] 825 - a simple 1800 office keyboard
« Reply #10 on: Mon, 14 July 2025, 10:35:01 »
I really like this. I would like to see 1.5-1.5-7-1.5-1.5 bottom row compatibility.
Offline yz
« Reply #11 on: Tue, 15 July 2025, 00:50:32 »
if it doesn't make the bottom row too much of a swiss cheese, I'll request the PCB designer to look into adding this :thumb:
Offline yz
« Reply #12 on: Sat, 19 July 2025, 11:20:00 »
/list removed, cheers for the 🍆 simone
« Last Edit: Sat, 19 July 2025, 11:21:41 by yz »
Offline jd
  • 60%
« Reply #13 on: Sun, 20 July 2025, 12:21:04 »
Great design. I will definitely keep an eye out for the group buy later this year.  :thumb:
Offline LogolicusZ
  • Location: Land of Cheese with many holes and Tall Mountains with chocolate
« Reply #14 on: Mon, 21 July 2025, 07:41:08 »
Definitely interested in this, cool project!
Offline yz
Re: [IC] 825 - a simple 1800 office keyboard (new updates)
« Reply #15 on: Thu, 06 November 2025, 01:50:09 »
Changelog (06/11/25)
Typing test uploaded.
PCB supported layout updated.
Design and prices finalised.
Vendors to be announced soon.
Offline VXQN
« Reply #16 on: Thu, 06 November 2025, 02:48:28 »
Any chance of adding a 2u key on the bottom row of the numpad for those keysets that don't have a 1u zero key?
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #17 on: Thu, 06 November 2025, 04:27:15 »
I would cry if I had to sit in the office from 8 to 5.
Offline yz
« Reply #18 on: Fri, 07 November 2025, 07:41:34 »
currently speaking with the PCB designer on this, shouldn't be too difficult to add. I'll provide an update here if that happens  :thumb:
good thing anodised aluminium is Tear-Resistant™ ;D
Offline phatmasterq
« Reply #19 on: Fri, 07 November 2025, 20:02:06 »
i'm in. i still need to build my Arc, but i'm in.
Offline yz
« Reply #20 on: Sun, 09 November 2025, 10:35:46 »
my guy it's been almost 2 years :eek:
Offline jd
  • 60%
« Reply #21 on: Sun, 09 November 2025, 20:06:41 »
Interested in this. I like simple 1800s.
Offline yz
« Reply #22 on: Thu, 13 November 2025, 06:26:26 »
Added EU vendor
Offline Zenihalt
Re: [IC] 825 - a simple 1800 office keyboard (EU/NA/Asia/AU vendors added)
« Reply #23 on: Mon, 24 November 2025, 01:49:18 »
Looks really clean! I'm tempted to buy it.
Offline JohnJamesPreston
« Reply #24 on: Mon, 24 November 2025, 14:37:02 »
I'm in !!!  :eek:
Offline yz
« Reply #25 on: Sun, 30 November 2025, 20:49:18 »
updated PCB layout to accommodate this
« Reply #26 on: Tue, 02 December 2025, 20:53:21 »
Looks Clean
