Author Topic: [Pre-Order] 79USD Weikav Nut65 Tri-mode Mechanical Keyboard - Large light bar  (Read 23064 times)
Offline john08099
  • Velocifire MK
  • * Moderator
    • Mechanical keyboards for typers
NUT65
Designed by WEIKAV Studio
Description
Hey everyone!
Today, we are excited to introduce the all-new Nut65 mechanical keyboard — a stunning blend of advanced craftsmanship, customizable features, and eye-catching design. Whether you’re a gamer, a creator, or just someone who loves quality gear, Nut65 offers a premium experience like no other. And the best part? Pre-orders are now live! Don’t miss your chance to be among the first to get your hands on this incredible keyboard. Keep reading to learn what makes Nut65 so special!🌰🌰🌰
Color Options
Anodized Black
Anodized Silver
Anodized Red
E-coat White
E-coat Milky White
E-coat Pink
Highlights
1. Pure CNC carving craftsmanship with 220 mesh anodizing/electrophoresis for an ultra-premium feel! A total of six colors for you to choose from. (Anodized Black, Anodized Silver, Anodized Red, E-coat White, E-coat Milky White, E-coat Pink
2. Three-mode connection supporting multiple devices and scenes! Can pair up to 5 devices, with quick switching to connect 3 Bluetooth devices. Optimize the wireless connection module, making it more stable and smooth, and allowing for seamless multitasking.
FN+Q/W/E to switch Bluetooth mode
FN+R to switch to 2.4G mode
FN+T to switch to wired mode
3. 8-pin magnetic contact pins for easier disassembly and assembly! In order to increase the anti-oxidation life of the pin and the connection stability, the touch pin adopts an 8-pin transmission, which improves the customized keyboard experience in many aspects.
4. Quick-release structure for effortless maintenance and upgrades! Equipped with a new ball model to optimize the pulling force, achieve better disassembly strength, and achieve a silky, quick disassembly effect. Anti-collision silicone is added to the four corners of the keyboard to achieve soft contact between the top and bottom cases.
5. Self-developed web interface + VIA dual-driver, allowing personalized customization with ease!
6. Dual gasket mount with a plate gasket and PCB gasket — delivering an outstanding tactile experience! Two different structures can be freely modified and switched, allowing you to deeply experience the fun of customization.
7. And the most impressive features include:
Four-segment RGB light strip at the front, built-in microphone, with lighting that "dances" dynamically to music!
Four dazzling lighting effects:
Flowing light from left to right
Flowing light from right to left
Central to both sides' diffusion
Both sides are converging on the center
8. Detailed upgrade: The spacebar is equipped with five LEDs, making the lighting more vibrant and colorful!
9. The back of Nut65 continues the Weikav multi-process design concept, with storage compartments, decorative parts, anode back plate, metal patches and other designs, and a variety of processes create a textured back design.
10. 6000mAh large capacity battery
Video
Specifications
Layout: ANSI layout
Mount: PCB Gasket Mount Structure
Case material: CNC Aluminum 6063
Processing: High Quality 220 mesh Anodization & e-Coat Finishing
Quick Assembly System: Ball-catched
Anodized aluminum weight with dongle compartment
Sound-activated RGB lighting effect
Flex Cut 1.2mm Hot swappable PCB, South Facing RGB
Horizontal Flex Cut FR4 Plate
Padding: 4 Layers
Connectivity: Wired / 2.4G / Bluetooth
Battery: 6000 mAh
QMK/VIA compatible
Does not include switches or keycaps
Dimensions: 314*113*19.5 mm
Weight: 1.12kg
Including: Keyboard*1, Keycap&Switch puller*1, USB cable, Manual
Manufacturer: Weikav
Price Info
Price: From 79USD
🚀 Pre-order ends on August 14!
Order processing begins on August 15!
Pre-order now to enjoy a 20% discount — don’t miss out!
Purchase Now
Please feel free to ask us any questions about the keyboard below! :)
Welcome to join our Discord and follow our Instagram,TikTok, YouTube  for more discussion, latest update and questions! :)
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
