Author Topic: [IC] Mask Off Keyboard  (Read 22381 times)
Offline MrEsosmao
« on: Sat, 09 August 2025, 19:03:25 »
Mask Off (MO)
More shots coming soon, stay tuned!
So what's the story behind Mask Off?
After a break from designing keyboards since the Vanguard65, I found myself drawn back by a wave of inspiration: from the sharp edges of brutalism, to the neon glow of cyberpunk, and the clean lines of futuristic designs.
Most importantly, I felt the hobby needed shaking up again.
While at a local meetup, I was hearing the general consensus that the state of keyboards were starting to blend together only strengthened that feeling.
So here I am on a mission to showcase another custom keeb that provides a personalized experience to add to the keyboard collection.
Mask Off (MO), is a keyboard kit that serves both minimalism aesthetics to fit any modern day environment.
Why the name Mask Off?
The internals of a keyboard are hidden inside its aluminum shell. My goal was to design a keeb that reveals its one true self, to represent the activity occurring beneath.
This interest check is intended for you to help out with the following:
  • Include foam dampening kit?
  • ISO support for my Euro friends?
  • Poll to boil color option for a limited edition version.
  • Add-on plate material options
  • Bluetooth support?
>>CLICK HERE TO INTEREST CHECK FORM<<
Specifications
365mm (l) x 102mm (w)
Layout
- 65% Compact
Plate Materials
Coming soon
Typing Angle
7 degrees
Front Height
18mm
Weight
Internal weight
Mount
Gasket Sock PCB Mount
Case Materials
Top - ALU 6063
Bottom - ALU 6063
Cutouts - Acrylic
PCB
  • Custom designed hotswap with underglow
  • ANSI/ISO hotswap support
  • QMK/VIA compatible
  • Split backspace support
  • Kailh hotswap sockets
  • Universal USB-C daughterboard
Colorways
At the moment, I need to be realistic and would really like your help to reduce this down.
Atm, Silver will be primary color.
Group Buy Information
Pricing: TBD
Extras
  • Plate: TBD
  • Plate: TBD
  • Plate: TBD
  • Plate: TBD
  • Plate: TBD
  • Plate: TBD
  • Hotswap PCB
Timeline:
  • Start Date: TBD
  • End Date: TBD
  • Delivery Date: TBD
Main Vendors:
  • USA: Keebfront
  • CA: TBD
  • SEA/PH: TBD
  • OCE/AUS: TBD
  • EUROPE:TBD
  • UK: TBD
  • MEXICO: TBD
  • LATAM (ARGENTINA): TBD
  • MALAYSIA: TBD
  • INDONESIA: TBD
Show your support
Add this to your signature to show your support
Code: [Select]
[url=https://geekhack.org/index.php?topic=118837.0][img]https://i.imgur.com/H4D2PEx.png[/img][/url]
« Last Edit: Wed, 13 August 2025, 20:35:12 by MrEsosmao »
Offline MrEsosmao
Re: [IC] Mask Off Keyboard
« Reply #1 on: Sat, 09 August 2025, 19:04:15 »
Reserved
Offline azhdar
  • Praise the AZERTY god
« Reply #2 on: Sun, 10 August 2025, 04:25:14 »
ISO ?
Azerty Propagandiste
Offline MrEsosmao
« Reply #3 on: Sun, 10 August 2025, 13:38:28 »
Offline dinobx
« Reply #4 on: Sun, 10 August 2025, 17:10:49 »
I love the look. Will more info about the side design detailing be revealed? I'm guessing it's a transparent core PCB and the transparent cover is acrylic? Excited to see where this goes.
Offline Shintaro
« Reply #5 on: Sun, 10 August 2025, 21:01:50 »
I thought it was a keyboard for Kamen Rider, like Kamen Rider W. If the lights on the left and right turn green and purple :)
Offline MrEsosmao
« Reply #6 on: Mon, 11 August 2025, 15:34:14 »
Guess I've just unlocked Kamen Rider Typing Form  :)
P.S. The lights can be altered to your preference within VIA and you can leverage all of their light FX.
« Last Edit: Tue, 12 August 2025, 14:18:27 by MrEsosmao »
Offline BSGalaxy
« Reply #7 on: Tue, 12 August 2025, 11:17:44 »
I really dig the aesthetic. Filled out the IC, hope to see it in GB soon!
Moon TKL / Frog / CW88 / Glacier80 / Mode80 /Monokei Hiro
GMK JP Desko / JTK Night Sakura / GMK Rouge / KAT Great Wave / GMK Birch / GMK Mictlan
Offline MrEsosmao
« Reply #8 on: Tue, 12 August 2025, 17:28:17 »
Could definitely show the process if that is of interest. Anyone else interested in this breakdown?
Offline lazaret
« Reply #9 on: Wed, 13 August 2025, 14:41:32 »
Yes please!
Offline Mr.RotKiv
« Reply #10 on: Thu, 14 August 2025, 02:12:19 »
Definitely interested  :)
Offline Surefoot
« Reply #11 on: Thu, 14 August 2025, 09:21:06 »
Love this design. I'm in (for an ISO version).
Offline MrEsosmao
« Reply #12 on: Fri, 15 August 2025, 14:52:46 »
Thanks!  ;D
Offline FOURRINGS
« Reply #13 on: Sun, 17 August 2025, 04:40:09 »
I love the Cyberpunk glowing aesthetic. Very nice.
Offline MrEsosmao
« Reply #14 on: Tue, 19 August 2025, 13:20:59 »
Thanks! More details coming soon.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #15 on: Tue, 19 August 2025, 14:13:20 »
Filled out the IC
A Ghost From The Past
Offline MrEsosmao
« Reply #16 on: Wed, 20 August 2025, 12:42:37 »
Offline IL25
« Reply #17 on: Fri, 22 August 2025, 04:09:01 »
I love the design and the compatibility with ISO format.
I sent you a DM on Geekhack Messages. Could you check it please.
Offline MrEsosmao
« Reply #18 on: Sat, 23 August 2025, 11:28:41 »
Got your message. Can you send me your discord or IG handle?
Offline MrEsosmao
« Reply #19 on: Tue, 26 August 2025, 14:09:50 »
Appreciate you! More updates coming soon.  :thumb:
