Author Topic: [GB] Altair & Altair-X Round 2  (Read 18996 times)
Offline upas
« on: Mon, 25 August 2025, 16:06:44 »
Altair / Altair-X Round 2
Live September 19th to October 20th
ETA Q3 2026
Altair is coming back to GB! We're keeping the design the same, but offering some new additional colors and addons that can be used with the original round! Check out the CannonKeys listing for even more info, images, and renders!
What's New?
  • New colors - Black, Camo Green, Navy, Silver
  • Soft carrying pouch addon
  • Aluminum weight with threaded hole addon for tripod mounts
  • New PBS keycap set with Altair kit
  • Coiled USB cable to connect both halves together as an addon
  • Solder PCB Addon
  • Improved screw threads
Colors
Black
Camo Green
Navy
Silver
Round 1 Proto Photos
Pricing
The keyboard kit pricing will start at $300 for Altair-X & $315 for Altair- the same as R1.
Altair Addons & Pricing
  • Extra set of 2 PC plates - $40
  • Extra set of 2 alu plates - $55
  • Extra set of 2 FR4 plates - $24
  • Extra set of 2 Hotswap PCBs - $55[
  • Extra set of 2 Solder PCBs - $50
  • Foam kit - $28
  • Set of 2 steel weight - $135
  • Set of 2 alu tripod weights - $45
Altair-X Addons & Pricing
  • Extra set of 2 PC plates - $37
  • Extra set of 2 alu plates - $52
  • Extra set of 2 FR4 plates - $21
  • Extra set of 2 Hotswap PCBs - $51[
  • Extra set of 2 Solder PCBs - $46
  • Foam kit - $26
  • Set of 2 steel weight - $130
  • Set of 2 alu tripod weights - $41
Shared Addons & Pricing
  • Extra gaskets - $7
  • Extra USB-C cable - $5
  • Extra set of 2 daughterboards - $11
  • Set of 2 wooden wrist rests - $28
  • Set of 24 feet - $5
  • Soft carrying sleeve - $13
  • Coiled USB-C interconnect cable - $5
PBS Set Addon
We are working on a new keycap set in the PBS profile to be sold alongside Altair & Altair-X. It will be a single kit for both units, and we hope the price will be under $30! We'll share more details and renders once the design is finalized.
Kit Contents
  • The case halves
  • Polycarbonate plates
  • Brass weights per half
  • PCB and daughterboard per half, along with their ribbon cables
  • Straight USB-C to USB-C cable for interconnect use
  • Custom hard carrying case
  • Rubber feet and gaskets
  • Screws and hardware for assembly
Specifications
  • Typing angle: 7deg
  • Materials: Aluminum case, polycarbonate plate (by default), brass weight
  • Manufacturer: Hongtu
  • Weight (both halves combined): ~1.2kg (Altair 5-row) | ~900g (Altair-X 4-row)
  • Dimensions (per half): ~143.6 x 126.4 x 30.0mm (Altair 5-row) | ~143.6 x 107.4 x 27.9mm (Altair-X 4-row)
  • PCB: 1.2mm thick; hotswap
Vendors
  • US: CannonKeys
  • UK: Mechboards
  • CN: zFrontier
  • KR: Swagkeys
  • OCE: KeebzNCables
  • EU: Keygem
  • JP: Yusha Kobo
  • ID: Acid & Co
« Last Edit: Thu, 18 September 2025, 07:30:28 by upas »
Offline upas
Re: [GB] Altair & Altair-X Round 2
« Reply #1 on: Mon, 25 August 2025, 18:27:45 »
Reserved
Offline idealape
« Reply #2 on: Tue, 26 August 2025, 11:42:02 »
No rosegold ?
Sent from my CPH2581 using Tapatalk
Offline stomaha
« Reply #3 on: Tue, 26 August 2025, 19:22:39 »
Yes please
Offline momos
« Reply #4 on: Fri, 29 August 2025, 03:27:35 »
First of all, thank you for Round 2. However, I do have a few things to say. First, why weren't all color candidate samples presented at the IC stage? Many people likely struggle to visualize colors accurately without seeing actual swatches. For example, take orange, the range of shades within that color is very broad. Some oranges might be preferred, while others might not be preferred. Therefore, I think presenting all color samples is essential for an appropriate IC.
And, you mentioned on Discord recently that the only colors shown as samples—red and beige—were actually your favorite colors. What do you think about that? Was that truly an appropriate IC?
Furthermore, one of the colors ultimately chosen was camo green, but at the IC stage, it was forest green. Unfortunately, camo green and forest green are different colors. Many people who voted for forest green must have been surprised by the result, right?
I have said a lot above, and I hope they can serve as a reference for future ICs.
Offline emilyvis
« Reply #5 on: Wed, 03 September 2025, 04:53:54 »
The Altair and Altair-X Round 2 look like fantastic updates that stay true to the original design while offering meaningful enhancements. The addition of new colors and versatile addons like the soft carrying pouch, aluminum weights, and the PBS keycap set really expand customization options. I appreciate the focus on quality with improved screw threads and the inclusion of both solder and hot-swap PCB options. Overall, it seems like a well-rounded package for enthusiasts seeking a premium, customizable keyboard with a sleek design. Excited to see how the community responds once these are released!
Offline GG-Bond
    • github
« Reply #6 on: Wed, 03 September 2025, 08:22:00 »
So, if I understand correctly, the USB-C on the custom daughterboards is used to:
1.Connect the left and right PCBs,
2.Connect one of the PCBs to the computer,
3.Enable gasket mounting.
Is that right? Can either the left or the right PCB be used to connect to the computer, or is it limited to just one side?
Offline upas
« Reply #7 on: Thu, 04 September 2025, 17:40:50 »
The keyset for the Altair has been finalized! We will be offering a single kit of PBS Cirispin, in collaboration with keebibi. We're pretty certain MSRP will be $35 for the single kit, but we're still working out the small details.
Offline quaks
« Reply #8 on: Fri, 05 September 2025, 02:39:17 »
Can we get a 2nd shift, for people who use the enter on the thumb cluster? Also why are there 2 raise? Is one of them supposed to be fn?
Offline upas
« Reply #9 on: Fri, 05 September 2025, 08:17:32 »
The kitting will likely stay the same, as the goal is to keep the kitting to the stock layout and not much else. In the future, we will have a very robust 40s kit that will have a ton more coverage if that is something you're interested in. The kitting for this will be similar to PBS MV Classic. Regarding the extra raise, the original set had two raise and we wanted it to be here in the second round as well. We have to make a lot of choices when kitting out something as limited as this, so unfortunately there will be some things people want that will not make the cut.
Offline upas
« Reply #10 on: Tue, 16 September 2025, 08:25:59 »
Final vendor list confirmed!:
  • US: CannonKeys
  • UK: Mechboards
  • CN: KBDFans
  • KR: Swagkeys
  • OCE: KeebzNCables
  • EU: Keygem
  • JP: Yusha Kobo
  • ID: Acid & Co
