Author Topic: [GB] NULL65 Series 2.0 Wood Keyboard Kit  (Read 11649 times)
Offline sarahn27
    • Null Design Co
« on: Thu, 28 August 2025, 21:45:01 »
UPDATE 10/6: Group buy has now ended. Thanks for your orders!
Group Buy Period: August 25 - October 6, 2025
Estimated Fulfillment Date: Q1 2026
Barebones Kit Base Price: $169
The NULL65 Series 2.0 is the next generation of the original Null Design Co. size 65% flagship wood keyboard case. Available as a barebones kit, it includes all the essentials you need for your next premium custom keyboard build. Now featuring removable side accents, giving you greater flexibility and even more design options.
Group Buy Page
Gallery
Sound Tests
Photography
New for Series 2.0
  • For the first time, a full barebones kit will be provided (including PCB, plate, foam, etc.).
  • Side accents are now removable! This allows you to customize your build even more by swapping out different accent styles and materials.
  • An extra internal weight was added, giving the board more heft, and a more premium feel and sound. Internal weights are now attached with screws (vs. tape), allowing you to both install and remove them more easily. The weights also act as stabilizers for the wood case, similar to how wood table tops are secured with metal bars. A set of aluminum weights is included with all case purchases, with the option to upgrade to brass if desired.
  • New premium finishes were added, for both the wood case and the metal side accents. For wood, you can now choose from Ink Black or Whitewash, and for the side accents, both brass and stainless steel materials are now available in a fluted option.
  • The top edge profile for case customization has been standardized to a chamfered finish. This ensures future compatibility with accessory items (like a matching numpad), simplifies stock management, and strengthens the case’s design language, since the chamfer has consistently been both a customer favorite and a signature detail of our cases.
Example Colorways
Just a few of the many possible combinations!
Kit Options and Pricing
Price for the kit will start at $169, with additional costs for optional add-ons and upgrades.
  • Wood Finish: Walnut, Oak, Maple, Cherry, Ink Black - Ash (+$10), Whitewash - Ash (+$10)
  • USB Accent: Brass or Stainless
  • Side Accent: Brass / Brushed, Brass / Fluted (+$6), Stainless / Brushed, Stainless / Fluted (+$6)
  • Hotswap PCB (wired only, QMK/VIA Compatible): ANSI or ISO (+$4)
  • Universal Switch Plate: Aluminum, Polycarbonate (+$10), or Brass (+$40)
Optional Add-Ons
  • Wrist Rests ($45): Walnut, Oak, Maple, Cherry, Ink Black (+$4), Whitewash (+$4)
  • O-Ring Mod Kit ($5)
  • Foam Kit ($29): Includes Poron case foam, Poron switch plate foam, and PE PCB foam
  • Metal Keyboard Feet ($19): Brass or Stainless Steel
  • Brushed Brass Weights Set ($45)
Specifications
  • Case Mounting Style: Tray Mount (2 middle standoffs can be removed and left out for a softer, more flexible typing experience)
  • Case Profile: High
  • Case Front Height: 25mm (1 inch)
  • Typing Angle: 6° (with add-on feet), or 0° (no feet)
  • Weight: ~2.5lbs (base kit), or ~3.5lbs (with brass weights add-on)
  • Hotswap PCB:
    • QMK/VIA compatible
    • Onboard USB-C connector (wired-only mode)
    • 1.6mm thick
    • Per-Key RGB LEDs
Included Parts
  • Wood case with metal USB accent detail
  • Removable side accents set (x2) with mounting screws (x4)
  • Aluminum weights set (x2) with mounting screws (x4)
  • SKUF silicone adhesive-backed feet (x4)
  • Hardware kit with assembly tools
  • Hotswap PCB
  • Switch Plate
Finishes
  • All wood products are finished with a hardwax oil, and can be easily touched up.
  • All metal accents and feet are solid (not plated or anodized), and left bare metal. Brass will slowly patina over time, creating a beautiful living finish. If this is not desired, the metal can be gently re-brushed using a maroon Scotch-Brite pad to restore its original bright appearance.
  • All brass weights are coated with a layer of lacquer to protect against accidental electrical shorts.
  • All brass switch plates are coated with a layer of lacquer to protect against tarnishing and fingerprints.
Group Buy Page
If you have any questions, or feedback about things you like/don't like, feel free to message me here on Reddit or on my website! Join the Discord or visit the website to see customer reviews and build photos.
~Sarah
« Last Edit: Mon, 06 October 2025, 22:46:13 by sarahn27 »
Re: [GB] NULL65 Series 2.0 Wood Keyboard Kit
« Reply #1 on: Fri, 29 August 2025, 11:16:09 »
Approved :thumb:
Offline vhaarr
« Reply #2 on: Sat, 30 August 2025, 01:18:31 »
Please do a 60% hhkb layout one :drool:
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline sarahn27
    • Null Design Co
« Reply #3 on: Sun, 31 August 2025, 14:12:05 »
I've never tried an hhkb before but I do love the symmetrical layout... so a 60% one might be in the cards. What are the other benefits to this layout that you see?
Offline B4zookaw
« Reply #4 on: Mon, 01 September 2025, 03:34:00 »
Is PCB 1.5mm or 1.6mm? (e.g. is the 1.5mm a typo?)
Offline sarahn27
    • Null Design Co
« Reply #5 on: Mon, 01 September 2025, 10:18:16 »
My bad, thanks for catching that! It should be 1.6mm.
Offline nathanchere
« Reply #6 on: Mon, 15 September 2025, 07:29:36 »
This  ;D ;D ;D
