Author Topic: [IC] Origami: Kitsune – 70% FRL-TKL  (Read 11068 times)
Offline Antagonist
« on: Fri, 29 August 2025, 08:14:54 »
[IC] Origami Keys: Kitsune
Designed by: Origami Keys
Interest Check Form
Join our Discord
INTRODUCTION
We designed the Kitsune as a playful yet sophisticated 70% FRL-TKL keyboard, aiming to reinterpret the bold geometry of classic mechanical keyboards through modern innovation. Inspired by fox origami, its polygonal form is shaped with sharp folds and intersecting planes to express a sculptural presence and bring a sense of artistry to its case design.
DESIGN PHILOSOPHY
We set out to embrace a seamed design aesthetic, treating visual breaks as a defining part of the board’s character rather than concealing them. With this in mind, we carried a polygonal theme through every element, from the angular case to the faceted copper weight, so that each surface and edge contributes to a unified, origami-inspired vision.
SPECIFICATIONS
Layout: 70% FRL-TKL
Mounting: Top Mount + PCB Mount
Typing Angle: 9°
Front Height: 16.99mm
Case Material: Aluminum 6063
Weight Material: Copper
Features: LED Accent System
PCB: 1.6mm Hotswap or Solder (with daughterboard)
Plates: Aluminum, PC, FR4, Carbon Fiber
Finish: Anodized
KIT CONTENTS
• CNC aluminum top & bottom case
• Copper weight
• LED diffuser & modules
• Multi-layout PCB (Hotswap or Solder)
• USB-C daughterboard + JST cable
• Hard carrying case
• Dampening foams
• Rubber feet
• Hardware kit
• Quick start guide
RENDER GALLERY
Renders by: Junocchi
LAYOUT SUPPORT
Primary: 70% FRL-TKL
Options: WK / WKL
Switch Support: 3-pin & 5-pin
PCB: Hotswap or Solder
PCB DETAILS
Thickness: 1.6mm
Lighting: Dedicated LED system
Connectivity: USB-C daughterboard (JST)
Firmware: QMK/VIA supported
Hotswap
Solder
DISCLAIMER
Origami Keys is an independent studio and not affiliated with Atelier by Pluskb or its other Origami projects. While we share an appreciation for the Origami theme, our boards are distinct in design and direction, and we aim to present them clearly to avoid confusion.
THE ORIGAMI SERIES
Kitsune is the first entry in the Origami Series, a lineup translating the art of paper folding into functional keyboards.
« Last Edit: Mon, 22 September 2025, 02:59:17 by Antagonist »
Offline jquema
Re: [IC] Origami: Kitsune – 70% FRL-TKL
« Reply #1 on: Sun, 31 August 2025, 12:59:16 »
Looks hefty. Will this also be.sold with a brass weight?
Offline Gtour
  • Just a random guy passionate about keyboards.
« Reply #2 on: Sun, 31 August 2025, 14:28:44 »
Really based project for your first one, GL!
And thanks for rendering Prussian Alert on it :)
Offline re1neke
« Reply #3 on: Sun, 31 August 2025, 15:36:32 »
I see the fox - I'm in!
« Reply #4 on: Sun, 31 August 2025, 19:25:15 »
Do you have any regional vendors in mind?
Online BJW
« Reply #5 on: Sun, 31 August 2025, 21:35:37 »
thought of the origami tkl
Offline bluntkrayon
« Reply #6 on: Mon, 01 September 2025, 02:33:44 »
Would love some playful colour options. An e-coat yellow or (ano or e-cot)  Hunter orange would be amazing! Also please have a LED caps lock indicator. Not fussed with brass or copper, but a coated weight would be nice as an alternative.
Definitively following! Loving the angles on this and the cherry lip!
Offline Potemkin
« Reply #7 on: Mon, 01 September 2025, 04:09:38 »
Are you related to Origami TKL?
Offline Antagonist
« Reply #8 on: Wed, 03 September 2025, 23:08:51 »
Thanks for the interest! We’re planning for the board to support a weight option. Brass is definitely being considered, though we’re also exploring other materials to balance aesthetics, feel, and cost. Nothing is final yet, so feedback on preferred weight materials is welcome.
Offline Antagonist
« Reply #9 on: Wed, 03 September 2025, 23:10:27 »
We don’t have confirmed vendors yet. At this stage we’re gathering feedback and gauging interest by region, which will help guide which vendors we approach. If there are specific vendors you’d like to see carry the board, feel free to suggest them.
Offline Antagonist
« Reply #10 on: Wed, 03 September 2025, 23:12:35 »
Good question. We are not related to Atelier by Pluskb or its Origami boards such as the Origami TKL. Our studio is called Origami Keys, and Origami is the theme behind our design philosophy. To avoid confusion, we’re naming this project “Origami Keys: Kitsune.”
Offline Antagonist
« Reply #11 on: Wed, 03 September 2025, 23:14:38 »
Thank you, that means a lot! And huge respect for your work on Prussian Alert, it’s a stunning set and it fit the board perfectly in the renders. Really appreciate you letting us showcase it.
Offline Antagonist
« Reply #12 on: Wed, 03 September 2025, 23:24:50 »
Thanks for the feedback! We’ve seen interest in playful finishes like e-coat yellow or hunter orange, so it’s something we’ll be keeping in mind as options develop. A caps lock LED indicator and coated weight are also ideas we’re exploring, though nothing is set in stone yet. Really glad you’re enjoying the angles and the cherry lip!
Offline bluntkrayon
« Reply #13 on: Thu, 04 September 2025, 00:59:56 »
KeebznCables in Ocenia would be my input.
Offline Antagonist
« Reply #14 on: Fri, 05 September 2025, 02:17:43 »
Renamed the project "Origami Keys: Kitsune"
Offline Yoshi_053
« Reply #15 on: Sun, 07 September 2025, 07:24:51 »
I really like the Design of the weight. The Discord link seems to be expired could you add a new one?
Offline Antagonist
« Reply #16 on: Sun, 07 September 2025, 12:57:18 »
Thank you for getting this to our attention. I have updated the discord link above. I'm glad you like the design!
updated link: https://discord.gg/yp3VsDF4Gx
Offline DirtyGingy
« Reply #17 on: Sun, 07 September 2025, 16:39:08 »
A relatively simple design, and I think that is its big strength. It looks nice, has some subtle accents when viewed on the desk, and uses a time tested mount. I like it.
Offline Antagonist
« Reply #18 on: Mon, 08 September 2025, 07:53:28 »
Thanks so much! We really wanted a design that feels clean and timeless. The geometric theme runs consistently through the board, so the details tie together nicely on the desk. Super happy you picked up on that
Offline Antagonist
« Reply #19 on: Mon, 22 September 2025, 03:02:18 »
KITSUNE INTEREST CHECK FORM IS LIVE!
We’ve just released the official Interest Check Form for Kitsune!
This is your chance to help shape the layouts, weight engravings, and overall design direction
Your input is incredibly valuable and will directly influence how the board develops.
We’d love for you to take a few minutes to share your thoughts.
Form Link: https://forms.gle/gt9ZwkYBsnZEZUac6
