Author Topic: Ten Dells with Alps  (Read 2856 times)
Offline NewbieOneKenobi
Ten Dells with Alps
« on: Fri, 05 November 2010, 19:23:42 »
I got ten of them in various stages of dilapidation. They generally tend to be GYUM90SK but at least two are 92SK (this one has no euro sign on 4, and a gray PS/2 tip) and 95 SK (this one has no Windows keys, and a grey PS/2 tip). There's more difference with milliamperages... 275, 75, 60...
They still need cleaning. I took the pictures a while after unpacking them. Each face shot is followed by the respective back label view. Could someone please help me identify the Alps switches involved with reasonable certainty? I know you never know 100% until you dissect the switch but I don't want to do that.
Offline SmallWalrus
Ten Dells with Alps
« Reply #1 on: Fri, 05 November 2010, 19:28:08 »
Quote from: NewbieOneKenobi;243212
Free cat included? :)
The Ducky keyboard community mass order thread
Get one set of keycaps free for a limited time only! :)
Ten Dells with Alps
« Reply #2 on: Fri, 05 November 2010, 19:32:04 »
Quote from: SmallWalrus;243213
Richard decided the packaging was quite attractive. :) Besides, I suspect he likes hardware.
Offline SmallWalrus
Ten Dells with Alps
« Reply #3 on: Fri, 05 November 2010, 19:33:09 »
I bet these are cheaper than the TVS keyboards! Heh
Ten Dells with Alps
« Reply #4 on: Fri, 05 November 2010, 19:48:22 »
They are, I got them for $11 each and $9 or $11 shipment total.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Ten Dells with Alps
« Reply #5 on: Fri, 05 November 2010, 21:29:32 »
Dilapi-what?
Anyway, it seems the first four numbers in the serial number encode the year and month of manufacture. The AT102 is the oldest, from early '95. A year later they had grown 3 more keys and a W. By '99 the € sign was standard. It's strange that one would be labeled AT101W when it's clearly a (102+3)-key version.
Not sure why so many of the Dells seem to be 1999 vintage. Mine is from '99, too. Maybe Dell ordered several years worth of production and sold these off thereafter. When did Alps get out of the switch business?
« Last Edit: Fri, 05 November 2010, 21:31:59 by keyb_gr »
Ten Dells with Alps
« Reply #6 on: Sat, 06 November 2010, 11:57:28 »
As far as I recall reading somewhere here, Alps got out of business around 2000. So from that point onward, there'd be "fake Alps", aka "fukka", I guess.
So I suppose I'll basically clean all of them and give some of the repeating 8 to other people, while keeping te ones without the € sign.
Any idea if the ones early '95 one without Windows keys and the one from '96 without the € sign could possibly contain different switches from the rest? I can tell for sure that they produce metallic vibration ("ping") that the newer ones don't. They also feel different to type on but I can't nail down the difference except that the oldest unit (without Windows keys) is the clickiest of all, probably requires the most force to actuate (still below a Model M) and has distinct actuation. A '99 one feels somewhat crispier, for comparison. Haven't had any luck removing the keys so far. So, any ideas as to which Alps should be there?
Ten Dells with Alps
« Reply #7 on: Sat, 06 November 2010, 12:11:22 »
Okay, I've managed to remove the caps. The casing of the switch is always black but you can peek into the hole in the middle and the look of that varies from black to grey. There are also some numbers and letters on the switch casing. Numbers stay the same across a keyboard (but differ among keyboards from the same year) but letters change.
Ten Dells with Alps
« Reply #8 on: Sun, 07 November 2010, 17:06:22 »
Bump. I've spent some time with the keyboards and it seems the older ones respond more slowly over the USB converter than the ones with a new purple PS/2 plug. I think I've noticed some transpositions too. They have a different feel than the newer units, more friction, I think, and more tactile, definitely more noticeable actuation, definitely more ping but maybe less smooth (and less interesting to type on), it feels like typing on the desk itself. Hard to tell the exact parameters, though. The '96 one feels different from the one from '95, which actually has a speaker. At the same time, all 10 units seem to have the same black alps on the exterior, the weight of the keyboards also seems to be the same.
Offline Oqsy
Ten Dells with Alps
« Reply #9 on: Sun, 07 November 2010, 19:01:10 »
use a plastic-safe lubricant, or even something like 303 Aerospace, and you'll find that all of the boards from all of the different eras feel identical.  Alps are the most prone to dirt / grit or uneven wear of all the mechanical switch variants encountered on geekhack...  a good clean and lube will make them all buttery fresh!
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline keyb_gr
  • Cherrified user
Ten Dells with Alps
« Reply #10 on: Sun, 07 November 2010, 20:50:28 »
Well, ALPS switches never were that expensive, so I guess that's gotta show somewhere.
Ten Dells with Alps
« Reply #11 on: Mon, 08 November 2010, 07:21:12 »
Quote from: Oqsy;243981
Thanks. I don't need to take off the caps, do I (they don't give)?
I kinda like the Alps. Probably more than brown Cherries.
