Author Topic: [GB] Vam05 Keyboard Kit - Live NOW  (Read 11596 times)
Offline GG-Bond
    • github
« on: Wed, 03 September 2025, 10:40:06 »
314360-0
Introduction*
Vam05 is a 40% keyboard with adjustable-hardness gasket mounting, featuring number keys 1–6 and arrow keys, balancing portability and functionality.
It runs on ZMK firmware, supporting both wired and BLE wireless modes, with real-time key remapping available via ZMK Studio (desktop or web).
The PCB is built around an nRF52840 chip, with MX hot-swap sockets and RGB under-glow. It also includes three multifunction indicator LEDs: layer switching, Caps Lock status, battery charging and level broadcast, and Bluetooth connection status.
PCB Specifications: https://github.com/Gasiro/vam05_PCB/tree/main?tab=readme-ov-file
Build instructions:https://www.youtube.com/watch?v=LCDWu6bFoLs
The Interest Check for Vam05 has already been conducted in the 40% Keyboards Discord (vam05 channel).
The case integrates a battery power toggle switch, allowing complete power-off when a battery is installed.
⚠️ Due to international shipping restrictions, batteries are not included. Vam05 is designed for the HAC-006 (Nintendo Switch Joy-Con battery, 3.7V 525mAh), which is inexpensive and widely available on Amazon and AliExpress.
Design Concept*
• Inspiration: The Vam05 layout is derived from Trashman’s v4n4g0n, a 40% keyboard featuring number keys 1–6 and arrow keys, which has been very popular in the 40% community.
• Design Goal: To deliver a modern wireless experience based on the classic v4n layout.
314362-1
Note: Due to routing for RGB and the physical size of the nRF52840 chip, the MCU can only be placed in the spacebar position. As a result, the wireless PCB does not support split spacebars. However, the case is compatible with the Monorail and Memoria PCB, which does support split spacebars.
• What Sets It Apart: Compact yet fully functional; includes arrow keys and number keys; modern aesthetics with practical indicator LEDs.
• Structural Design: Default typing angle is 4°. The back retains screw holes for optional PC feet, which increase the angle to 7.5° (this GB offers 7.5° PC feet as an optional add-on).
Specifications*
• Dimensions: 115.95 Χ 270.25 Χ 34.6 mm
• Typing Angle: 4° / 7.5° (with optional PC feet)
• Front Height: 18 mm
• Mounting System: Gasket mount with three hardness levels of silicone inserts included
• Case Material: Aluminium top case + PC bottom case
• Plate Material: FR4
• PCB: MX hot-swap, ZMK firmware support, wired + wireless dual mode
314364-2
Options
• Layout: v4n-JetVan layout (40% layout with number keys 1–6 and arrow keys)
• Top Case Colours: Silver / Sky Blue / Dark Violet / Lemon
• Bottom Case: Transparent PC
314366-3
314368-4
314370-5
314372-6
• Feet: Optional PC feet (typing angle 7.5°)
Kit Contents*
• Case (top case / bottom case / integrated power toggle switch) Χ1 set
• FR4 Plate Χ1
• Vam05 PCB Χ1
• Unified Daughterboard-C5 Χ1
• Foam set (mid-layer foam + switch pads)
• Gasket mounting system Χ1 set
• Accessories: feet and screw set
Vendor*
• Global: Kezewa https://kezewa.store/products/group-buy-vam05-keyboard-kit
Discord
• 40% Keyboards
https://discord.gg/jWwKSEWB
• - vam05 channel https://discord.com/channels/527180441950617611/1398993817776029777
Disclaimers
• Images are renders; final colours may vary slightly.
• Kit does not include switches or keycaps.
Price*: $289 (Silver)/ $308(Sky Blue / Dark Violet / Lemon)
GB Start and end date*: September 1st - October 1st, 2025
Estimated fulfillment date Time*: December 2025 – January 2026
« Last Edit: Wed, 03 September 2025, 16:54:06 by GG-Bond »
Re: [GB] Vam05 Keyboard Kit - Live NOW
« Reply #1 on: Fri, 05 September 2025, 14:12:34 »
Approved :thumb:
Offline Livid
« Reply #2 on: Wed, 24 September 2025, 14:37:44 »
Bump, buy this board people  :D
Offline GG-Bond
    • github
« Reply #3 on: Thu, 25 September 2025, 15:01:26 »
It gonna look great on  GMK CYL NERVEWRECKER isn't it?  ;D
Offline Tune Lab
« Reply #4 on: Wed, 15 October 2025, 03:12:19 »
I am already tempted ;D
