Author Topic: [IC] Osidian TKL V2  (Read 8665 times)
Offline Osidian
[IC] Osidian TKL V2
« on: Sun, 07 September 2025, 14:10:54 »
[IC] Osidian TKL V2
314441-0
Introduction
Osidian TKL V2, our second iteration that includes improvements to the kit materials, mounting structure, magnetic system and kit accessibility. The V2 includes three available colorways: White Carrara, Nero Marquina Black, and Lemurian Blue Labradorite. The V2 utilizes aluminum in place of the V1 ABS.
Alexotos Review
Photos by Alexotos
314445-1314443-2
314453-3314451-4
314447-5314479-6
Specifications
Included in Kit
- Stone casing / magnetic frame
- Magnetic aluminum top plate
- 1.5mm Brushed aluminum switch plate (silicone gasket mount)
- 3.5mm Poron plate foam
- Molex Pico-EZmate cable
Color options/finish
- White Carrara
- Nero Marquina Black
- Lemurian Blue Labradorite
PCB & Daughterboard
- Compatible with Cannonkeys Bastion TKL F12 Hotswap/Solder (F13 not included), and the F12/F13 Hotswap version.
- Unified S1 Daughterboard required
PCB & Daughterboard not included
Weight
- Fully assembled approx. 4.5 LBS / 2 KG
Dimensions
- Typing angle: 4 degrees
- Kit length & width: 375mm x 149mm
- Casing finished thickness: 18mm
- Total kit height: 23mm
Price
$449 USD
314457-7314459-8
314461-9314455-10
White Carrara
314465-11314467-12
314469-13314463-14
Nero Marquina Black
314473-15314475-16
314477-17314471-18
Socials
Website
Thanks so much for your time and interest!
Best regards,
Osidian
« Last Edit: Thu, 25 September 2025, 16:45:01 by Osidian »
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] Osidian TKL V2
« Reply #1 on: Sun, 07 September 2025, 14:12:57 »
Very cool finish on these!
Offline hwalker84
« Reply #2 on: Sun, 07 September 2025, 16:56:44 »
Already ordered the PCB and daughterboard. Pretty sure I'm going with the Nero Black with GMK Cosmos
Offline Osidian
« Reply #3 on: Sun, 07 September 2025, 20:07:01 »
Offline suppppmain
« Reply #4 on: Wed, 10 September 2025, 16:05:19 »
This is absolutely amazing! just wondering if there's any vendor information and also is Bastian the only PCB recommended?
Offline CEGeek
« Reply #5 on: Thu, 11 September 2025, 01:03:09 »
This is insane. I believe this stone material is exceptionally good for cushioning
Offline Osidian
« Reply #6 on: Thu, 11 September 2025, 19:12:59 »
The kits are available through osidian.ca. They were designed specifically around the Bastion TKL PCB, so fitment is guaranteed with that board. Other F12 TKL PCBs with a Molex connector should fit the case, but they haven’t been thoroughly tested to guarantee fitment.
