Author Topic: Good KVM switch  (Read 2378 times)
Offline codek
Good KVM switch
« on: Sat, 06 November 2010, 05:10:24 »
I need a realible KVM switch.  I currently run 3 thinkpads into 3 monitors but want to use only one keyboard at a time.  I'm posting this here because I just bought a couple of
Model M's
Dell AT101's
IBM Ultranav's
will check out
Model M13
HHKB Pro 2
Cherry G84-4100
I want to check these out without any compatability issues.
I also need a good ps/2 to usb converter for cheap, looking to buy 3
thanks in advance
Offline ricercar
  • mostly abides
Good KVM switch
« Reply #1 on: Sat, 06 November 2010, 11:23:09 »
I had VMware buy me Belkin KVMs when I worked there. I've never had Windows/Mac OS X/Linux fail to recognize the keyboard/display when booted to a Belkin KVM.
I think only nice things about Belkin KVMs. Well, except for the (lack of) availability of their <2 PC to 2 DVI display> KVM, which I'd buy in a heartbeat if I ever see it again.
Do a search for the $8 blue cube PS/2-to-USB converter. There is no substitute.
« Last Edit: Sat, 06 November 2010, 11:25:24 by ricercar »
Offline codek
Good KVM switch
« Reply #2 on: Sat, 06 November 2010, 21:09:31 »
Everyones seems to like the belkins.  Can I pretty much pick up any one of them?
Offline Soarer
Good KVM switch
« Reply #3 on: Sat, 06 November 2010, 21:35:22 »
I have a 4-port Aten which works well, wasn't cheap though. When I was researching which KVM to get, it came down to a toss up between Belkin and Aten as having the best reliability to price ratios.
If you don't need monitor switching then there should be a cheaper solution out there - not sure what they're called - a KM switch? Or if the machines are networked then for free you could try Synergy.  I've been meaning to give it a try myself, it looks pretty neat.
Offline codek
Good KVM switch
« Reply #4 on: Sat, 06 November 2010, 23:23:15 »
Quote from: Soarer;243626
Thank you for that link.  I'll definitely try it out.
Those Aten's are nice, like the rolls royce of KVM's but not sure I could afford the price tag right now... lol
