Author Topic: [GB] Onibi | 26th Sept-16th Oct  (Read 5146 times)
Offline kbdfans
« on: Sun, 28 September 2025, 00:06:57 »
Onibi
Build Video
Alexotos   Build Stream
Intro
Designer: Serajiman
“Beware the Onibi, for their beauty is a deadly trap, and their light a beacon to the afterlife. In the presence of these ghostly flames, one must tread carefully, lest they become another lost soul, forever wandering the night.”
Designed by Serajiman, in partnership with KBDFans, Onibi is a dual mounting-style TKL keyboard with design inspiration taken from Japanese folklore. It emphasises customisation, comfort and tasteful classicism with a twist.
Design Features
Onibi is a TKL with a comfortable 6.5 degree typing angle, 18mm front height and a variety of attractive design elements, taking inspiration from Japanese folklore and architecture.
The side profile was designed to somewhat resemble a Shinto shrine, apt given the namesake.
Featuring beautiful variable filleted edges which, when viewed from the top, provide a distinct and alluring shape and a comfortably rounded front lip.
The aim of the design was to aptly reflect the theme of Onibi – a flaming spirit that guides lost souls to the afterlife – the Shinto shrine being what I imagine their ‘natural habitat’ would be.
The flaming skull is my interpretation of Onibi, and it’s presence can be seen externally and internally.
Specs&Packing list
Specs
Layout: F12 TKL WK and WKL, angled "screwless"
Mounting: Top mount and gasket dumbbell
Typing Angle: 6.5 degrees
Materials: Aluminum
Front Height: 18 mm
Plate Options: Aluminium flex-cut, Carbon Fiber flex-cut, PC non-flex-cut, and PEI non-flex-cut
PCB: 1.6 mm solder/ Hotswap PCB, support VIA/VIAL/AVA
Weight (Built): around 3kg
Packing list
Top and bottom case x1
Copper weight bar x1
Silicone gasket x1 set
Rubber feet x1 set
Daughterboard x1
Screws x1 set
Force break tape x1 set
Light guide block x1
Carrying case x1
The PCB, Foam kit, and Plate are not included in the keyboard kit and must be purchased separately as an add-on.
GB date
26th Sept-16th Oct
Estimated shipping date: Q1, 2026
Photos
Onibi Ash
Anodized Racing Yellow
Mounting
Exploded View
Weight
PCB
1.6mm Solder PCB
1.6mm Hotswap PCB
Plate
None-Flex cut-PC Plate                              Non-Flex cut-PEI Plate
Flex cut-Aluminum Plate                            Flex cut-CF Plate
Layout
Dimensions
Color Options
Onibi Ash                                  Anodized Sliver
Anodized Gray                                  Anodized Black
Anodized Bronze ware                             Anodized Pine Green
Anodized Racing Yellow                             Anodized Dark Blue
Anodized Magenta                                   Anodized Red
Vendor List
US: Divinikey
EU: Eloquent Clicks
AU: Soupkeys
UK: Thocc Exchange
SG: Ktechs
CA: Deskhero
VN: BYS
Global: KBDfans
Re: [GB] Onibi | 26th Sept-16th Oct
« Reply #1 on: Mon, 06 October 2025, 14:32:05 »
Approved :thumb:
Offline kbdfans
« Reply #2 on: Tue, 07 October 2025, 20:01:48 »
Price during GB period: $338-$376 ;D
Offline Tune Lab
« Reply #3 on: Wed, 15 October 2025, 03:11:50 »
Excellent detail work
