Author Topic: Cleaning KB: Aerosol Air Duster costs $$$, alternative?  (Read 3096 times)
Offline codek
« on: Sat, 06 November 2010, 17:28:17 »
Just bought a couple of Model M's, M13, AT101's, ultranav's because of this site all within joining this site less than a week ago. Call me crazy.
I received them and they need a major cleaning but I'm sick of spending $$$$ on aerosol air dusters.
Anyone try a MetroVac air duster?  Price is right @ $44 but some reivews says it's overpowering and some say the pressure is weaker than aerosol air dusters.
http://www.amazon.com/Metro-Vacuum-ED500-500-Watt-Electric/dp/B001J4ZOAW/ref=sr_1_3?ie=UTF8&qid=1289082144&sr=8-3
I was thinking of spending a more and buying this
http://www.amazon.com/Metro-Vacuum-MDV2TA-DataVac-1-17-HP/dp/B0017DBMV0/ref=sr_1_7?s=hi&ie=UTF8&qid=1289082259&sr=1-7
or
http://www.amazon.com/Metro-Vacuum-SK-1-Sidekick-Motorcycle/dp/B000LQB24G/ref=sr_1_2?s=hi&ie=UTF8&qid=1289082249&sr=1-2
There are really powerful ones which I might consider buying since you can dry your car with them and do other heavy duty things with them.
I'd really prefer buying the $44 one if it does the job.   Anyone have experience with these air dusters?  Any recs?  What do you guys do?
Offline WhiteRice
« Reply #1 on: Sat, 06 November 2010, 17:34:18 »
Check the review section for ripster's review of the datavac. Sounds just like what you're looking for.
Offline upperguy
« Reply #2 on: Sat, 06 November 2010, 20:44:14 »
Everyone knows that the duster cans are only good for huffing.
Is the smaller DVR-1 powerful enough? or am I better off with a straw and my lungs
Offline codek
« Reply #3 on: Sat, 06 November 2010, 20:54:16 »
Quote from: ripster;243597
Here.
Great for bedroom shenanigans as well.
ripster, just read your review. Would you ever go a step up in the datavac series or does the 500E meet all your needs?
Offline codek
« Reply #4 on: Sat, 06 November 2010, 21:10:44 »
Quote from: ripster;243617
You mean like this vacuum/blower combo unit?
$230 and the Amazon reviews don't look so hot.
so all you need is the 500E cool
Offline didjamatic
« Reply #5 on: Sat, 06 November 2010, 22:03:39 »
If you keep water out of your system, a compressor and air hose with the air gun thingy works great as long as you don't get too carried away.
Yes, it's more upfront but it has so many uses you'll wonder how you ever lived without it.  I have a cheaper compressor that is extremely loud.  I wish I had one of these.  The tanks are small but it's very efficient at filling them up quickly.  I have a huge vertical tank unit but would rather have a smaller Makita.
« Last Edit: Sat, 06 November 2010, 22:09:06 by didjamatic »
Offline codek
« Reply #6 on: Sat, 06 November 2010, 23:09:57 »
Quote from: didjamatic;243639
That looks like a MAC2400 2.5hp which is about $300 at amazon.
The 2hp version is only $189.  Will the 2hp suffice? or if i get one just the MAC2400.  It looks way better than the MAC700.
Offline 8_INCH_FLOPPY
« Reply #7 on: Sun, 07 November 2010, 01:17:53 »
I'm pretty sure an ultrasonic cleaner would be both cheaper and more effective.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
