Author Topic: [IC]Piglet custom keyboard (LAST TWO DAYS )  (Read 13821 times)
Offline jacky
« on: Thu, 23 October 2025, 09:38:44 »
Gb start :https://www.jackylab.com/
PIGLET
Hi everyone,Today, we are excited to introduce our new keyboard, Piglet. It is a compact num pad, designed as an entry-level option, perfect for those who haven't yet experienced our products.
Piglet can be paired with our previously released Hippo 80% keyboard, and it also integrates seamlessly with other products from our family, as it follows the same design language. This is why we named it Piglet.
Design language
Piglet keeps the same ideas that guide all our designs — clean, modern, and detailed.
We wanted to make something small that still feels warm and well-balanced.
Its shape has soft lines and smooth corners. The colors are calm and gentle, making it easy to fit with different setups.
Even though it’s compact, Piglet still carries the same quality and design style as our other products.
Whether you use it alone or next to the Hippo 80%, Piglet looks like part of the same family — simple, thoughtful, and consistent.
Rendering
Specifications
Mounting System: Top Mount
Case Material: 6063 Aluminum (anodized/e-coating/coating), PC
Layout: WK/WKL
Back Weight: Brass
PCB: 1.6mm Hot-Swap (2.4g Bluetooth, Wired, Hotswap PCB)
Plate: Aluminum (E White) / PEI (Amber)
Typing Angle: 5.5 degrees
Case weight :~1.25KG
Case Color: Please fill in the table, and we will select 5 group-buy colors from it
IC form : https://shorturl.at/Co7ML
Layout
Sales and price
GB expected Date: November 10th
Group-Buy Price: $168
U.S. Tariffs:
Shipping cost will include tariffs.
About prototypes
For the release of Piglet, we are not providing prototypes for review,
only renderings for reference. We understand this is different from the usual group buy process,
 but even without samples, we assure you that the design and quality of Piglet will be held to the same high standards.
We will maintain our commitment to high quality, ensuring that every part of the production process meets our expectations.
The entire production process will be open and transparent, and we will keep you updated on the progress so that everyone
 who supports us can purchase with confidence.
Thank you for your understanding and support. Piglet will continue our tradition of pursuing high quality and innovation.
« Last Edit: Mon, 24 November 2025, 04:50:15 by jacky »
Offline Cucoo
Re: [IC]Piglet custom keyboard
« Reply #1 on: Thu, 23 October 2025, 09:49:48 »
Instabuy 😎
Will shipping also include EU vat?
Offline KeebDweeb_
    • KeebDweeb
« Reply #2 on: Thu, 23 October 2025, 10:24:59 »
instabuy for me to go with my piggy 60, bear 65 and Hippo
Offline basilkeys
« Reply #3 on: Thu, 23 October 2025, 11:45:44 »
Incredible! Beautiful! This design language has big aura even in small layouts. GLWGB!
« Reply #4 on: Thu, 23 October 2025, 16:54:07 »
Would prefer Anodized Silver to match my Hippo instead of Raw for a color option
Can't wait for this GB!
Offline jacky
« Reply #5 on: Fri, 24 October 2025, 07:58:42 »
Instabuy 😎
It’s possible, but we’ll need to confirm again when we’re ready to ship.
Offline jacky
« Reply #6 on: Sat, 25 October 2025, 06:04:49 »
Thank you
Offline GregRtings
« Reply #7 on: Sat, 25 October 2025, 15:53:47 »
Lovely. Am interested. Especially in the toothpaste colorway.
Offline KenGuru
« Reply #8 on: Mon, 27 October 2025, 13:41:31 »
This is very nice. Would personally like to see split zero and plus, if that is possible (maybe in a solderable PCB)?
« Last Edit: Mon, 27 October 2025, 13:53:26 by KenGuru »
Offline jacky
« Reply #9 on: Sat, 01 November 2025, 22:49:35 »
prob no soldering
Offline jacky
« Reply #10 on: Mon, 03 November 2025, 07:25:31 »
Should have
Offline jacky
« Reply #11 on: Tue, 04 November 2025, 11:08:16 »
Updates:
The final colors for our IC are E beige, silver, mint, plum, raw, and PC.
Offline jacky
« Reply #12 on: Tue, 11 November 2025, 20:15:12 »
Offline dom
  • allergic to hypocrisy
Re: [IC]Piglet custom keyboard (GB start )
« Reply #14 on: Fri, 14 November 2025, 04:23:57 »
Having no protos is a bit disrespectful. But GLWGB!
« Last Edit: Fri, 14 November 2025, 04:31:11 by dom »
Offline jacky
Re: [IC]Piglet custom keyboard (LAST TWO DAYS )
« Reply #15 on: Mon, 24 November 2025, 04:50:37 »
« Last Edit: Fri, 26 December 2025, 04:02:58 by jacky »
