Author Topic: [IC] TUTKEYS C.C.C.C  (Read 4804 times)
Offline sososoya
« on: Fri, 31 October 2025, 11:50:59 »
TUTKEYS C.C.C.C
Join Discord Server for updates XD
Intro
Long time no see, this is Soya, and today I'm bringing you the latest news about C.C.C.C.
Inspiration
In the summer of 2024, I rescued a less than one month old cow cat from the interlayer of the wall, which was also the design prototype of this keycap set.
“Cow cat is commonly referred to as black and white. Because it looks like a cow, it's called that. Cow cats are a common hybrid breed of domestic cats.”
Customize your cow cat
Each cow cat has a unique pattern, and we hope that C.C.C.C can create your own one-of-a-kind cow cat.
with [Base Kit]
You can also choose to replace the "Big Eyes" keycaps in the [Countom Cat Kit]
Assemble a cat meme
Uni :3(@unicouniuni3)
My cow cat.
Renders
Due to the influence of environment and lighting, the rendering color may differ from the actual object to some extent. Please refer to GMK CP for the white color code of the keycaps.
Astelier 8 / Lyra
Kitting
There may be changes, please refer to the GB post for accuracy.
Base Kit
Novelties Kit
Custom Cat Kit
Numpad Kit
Contact
If you are interested in this set, why not join my Discord server? I will post updates on the latest progress of TUTKEYS C.C.C.C from time to time there. (I will communicate with you using Google Translate XD)
Discord server:https://discord.gg/cFXNcGUbcf
Disclaimers
The renders may differ visually from the final product. In case of any discrepancy between the renders and the final product, the final product shall prevail.
