Author Topic: [IC] Haven 103 | Fullsize Haven  (Read 15485 times)
Offline papamao
« on: Wed, 05 November 2025, 02:54:47 »
Hello everyone,
This is Papamao from Atelier Haven. I would like to introduce the upcoming addition to the Haven Series.
Introducing: Haven 103
Part I: Design Philosophy
Comparing to previous Haven keyboards, the 103's design is more simplified and subjugate while keeping the typical architectural vibe that all Haven keyboards have. The side profile is still clean, linear, floaty and multi material like modern architecture to ensure the keyboard always look different and yet beautiful under varying lighting environment.
The main design technique used here is the cutting of rectangles and squares, forming triangles on different surfaces of materials to create a dancing light and shadow on the surface of the keyboard.
One of the front badge included in the kit is designed the way mentioned above, while the other badge is more simplified.
The type-C port side of the keyboard has enhanced volumetric design through the use of a thin plate of aluminum that is machined out from a thick block of metal, while filling out the blank with a block of PVD polished stainless steel or copper.
The front height is 16.7mm, rear height is 36.5mm, ekh is 20.9mm and the typing angle is 8.5 degrees.
Since full size keyboards are too long, the pcb and plate are divided into two parts: 60+F zone and function+pad zone, to ensure the consistency of typing feedbacks.
Due to the lower front height, even though the gasket is used on the plate, you will still expect a more top-like supportive, hard and consistent typing experience.
Part II: Spec
Full size 100% WK/WKL
Leafspring Plate + Silicon Gasket Screw Top Mount
Plate: Separated Main + Nav/Pad Aluminum Color Paired to Case by default
PCB:1.6mm CEM-3 QMK/VIAL Compatible Solder/Hotswap
Supported Layout
Solder
Hotswap
Typing Angle: 8.5
Front Height: 16.7mm
EKH: 20.9 mm
Weight: SE 2700g, FE&HE 3600g (Unbuilt)
ETA: 2026 Q2
Pricing: SE $400, FE $500 HE $540
What is included in the kit:
Keyboard Carrying Case
Assembled cases
two metal front badge
two pieces of PC block
one PCB, one plate
one set of ixpe foam
3.5mm poron and bottom case foam
24 pieces of silicon socks
one set of daughterboard plus magnetic cable
three pairs of silicon feet
extra top case screws
one metal artisan keycap.
Style I: Bevel Badge
Style II: Rectangular Badge
Part III: Color Config
HE: Ano Case + Highlight Chamfer + PVD Stainless Steel Weight + PVD Sandwich Stainless Steel Weight + PVD Badges
Anodized Gray Gold Aluminum+PVD copper SS Weights+Copper Highlights(540$)
Anodized Icy Blue Aluminum+PVD silver SS Weights+Silver Highlights(540$)
Anodized Black Aluminum Case+PVD black SS Weights+Copper Highlights(540$)
Anodized Silver Aluminum Case+PVD blue SS Weights+Blue Highlights(540$)
FE: Ano Case+ PVD Stainless Steel Weight+ PVD Stainless Steel Sandwich Weight + VPD Stainless Steel Badges
Anodized Gray Copper Aluminum+PVD Gray Copper SS Weights(500$)
Anodized Icy Blue Aluminum Case+PVD Silver SS Weights(500$)
Anodized Black Aluminum Case+PVD Black SS Weights(500$)
Anodized Crimson Aluminum Case+PVD Black SS Weights(500$)
Anodized Silver Aluminum Case+PVD blue SS Weights(500$)
Anodized Silver Aluminum Case+PVD Silver SS Weights(500$)
Anodized lavender Aluminum Case+PVD Silver SS Weights(500$)
Anodized Navy Aluminum Case+Copper Weights(470$)
Anodized Silver Aluminum Case+Copper Weights(470$)
SE: Ano Case+ PVD Stainless Steel Weight + Ano Aluminum Sandwich Weight + PVD Stainless Steel Badges
Anodized Black Aluminum Case+PVD Black SS Bottom Weight+Anodized Black Aluminum Middle Weight(420$)
Anodized Silver Aluminum Case+PVD Silver SS Bottom Weight+Anodized Crimson Aluminum Middle Weight(420$)
Part IV: Renders and Prototypes
Part V: Links
Discord
Thanks for your time of reading!
« Last Edit: Thu, 06 November 2025, 11:59:08 by papamao »
Offline papamao
Re: [IC] Haven 103 | Fullsize Haven
« Reply #1 on: Wed, 05 November 2025, 02:56:58 »
Reserved for updates
11/20 update: GB has started on Kibou, Typo!Works and Keyspensory. GB last until early December. Feel free to take a look of their page
« Last Edit: Thu, 20 November 2025, 03:32:23 by papamao »
« Reply #2 on: Wed, 05 November 2025, 04:06:25 »
This is the year of Full Size Boards
Offline Baron
  • oops its me
« Reply #3 on: Wed, 05 November 2025, 07:02:10 »
always happy to see full size
Offline JohnJamesPreston
« Reply #4 on: Wed, 05 November 2025, 18:44:29 »
Oh, I'm really interested!  :eek:
Offline Prestons Thoughts
    • YouTube Channel :D
« Reply #5 on: Thu, 06 November 2025, 00:21:09 »
Looks beautiful! Would love to showcase a prototype or review unit on my channel in the future :D
Offline hwalker84
« Reply #6 on: Thu, 06 November 2025, 10:36:30 »
Haven TKL is a special board to me. I’ve been waiting on this one for awhile. Just take my money!!!
Offline KeebDweeb_
    • KeebDweeb
« Reply #7 on: Thu, 06 November 2025, 11:08:29 »
Love my Haven TKL.  Def looking to grab the full sized version too!!
Offline godsson
« Reply #8 on: Thu, 13 November 2025, 18:02:57 »
Yes! We need more full size boards. The styling on this is insane.
Offline clay
  • No foams
« Reply #9 on: Thu, 11 June 2026, 12:45:59 »
I am wondering, has this ever materialized?
Offline ejbrownsd
« Reply #10 on: Fri, 12 June 2026, 12:17:54 »
Definitely interested if this materializes. Looks beautiful.
Offline Gemmmmmmmmmmmmmy
« Reply #11 on: Fri, 12 June 2026, 19:21:30 »
You missed it.
Life seems so much smaller
Swim to the moon
Offline INFILTRATION
« Reply #12 on: Sat, 13 June 2026, 16:56:08 »
oh man.. this had a china GB only? we need our GB as well.. come on guys bring it over.
Offline hwalker84
« Reply #13 on: Sun, 14 June 2026, 18:58:20 »
Keyspensory was the vendor who is shipping to the US. There's still some extras on the site. I'm US and got in on the GB
Offline hwalker84
« Reply #14 on: Sun, 14 June 2026, 19:05:46 »
It did. GB already ran but Keyspensory still has some extras. It is in route to the group buyers currently. I haven't received mine yet.
https://keyspensory.store/products/haven103-by-atelier-haven-11-03-11-25?_pos=1&_sid=a9b14df9d&_ss=r
