Advanced search
wanna switch?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Marketplace
Group Buys and Preorders
(Moderator:
Signature
[In Stock] GDK LAB KV1-65% keyboard Kit R2
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [In Stock] GDK LAB KV1-65% keyboard Kit R2 (Read 4329 times)
DashanYYY
Thread Starter
on:
Thu, 06 November 2025, 15:22:08 »
GDK Lab KV1-65 Keyboard R2
Product Link:
https://unikeyboards.com/products/gdk-lab-kv1-65-keyboard-kit
Unikeys Discord:
https://discord.gg/9PjWsc3Dxb
Index
1. Intro
2. Design
3. Features
4. Color options
5. Specifications
6. Inside the box
7. Reviews
8. Price Information
9. Vendors
1. Intro
The KV1-65 keyboard kit has an R2 now! Compared to the R1, there will be a few major changes:
1. New case colors available
2. New weight options available
3. Most importantly, a huge price cut!
2. Design
The case colors that will be included in this instock sale are:
Titanium Grey
Ano Black
Anodized Cyan
Spray Coated Sparkle Black
Spray Coated Retro White
Spray Coated Retro Grey
Spray Coated Lake Blue
Spray Coated Yellow
With the new weight options available
Metal Flow Finish Black Weight
Metal Flow Finish Silver Weight
Red Copper Weight
And our star: New stainless steel raw diagonal finish weight
3. Features
Ball-catch Structure
Make installation and debugging more convenient. And it was designed to have a crisper sound and clearer disassembly and assembly feedback.
Gasket Mount
The KV1-65% features a gasket design that utilizes custom silicone rubber bridges for support and a soft, cushioned feel.
VIA & QMK Support
VIA is a tool that enables keyboard configuration. With the VIA configurator, you can map keys to the physical layout of your keyboard.
Long-Lasting Battery Life
The KV1-65% offers 2 2500mAh battery, delivering up to 2 weeks of usage. Long battery life ensures uninterrupted work and entertainment, allowing you to stay productive and stay connected wirelessly for longer, without the need for frequent charging. What's more, it allows you to charge and use at the same time in wired mode.
4. Pricing
Ano case/Spray coated case + Red copper weight/SS Diagonal weight: 140 USD
Ano case/Spray coated case + Metal Flow Finish weight: 130 USD
FYI: Any unikeys content creator discount codes can be applied for this purchase
5. Specifications
Mount: Gasket mount
Connectivity: Single mode / Tri-mode
Material: 6063 CNC Aluminum (220 mesh)
Surfacing: Anodized, Spray paint
Acoustic: Poron pad *1/Bottom pad *1(Customers can try not adding any padsand still get a good typing sound)
Weight: Stainless steel matte PVD / Mirror PVD / Red copper
Case Weight: 1.4kg
Weight with switches and keycaps: 1.76kg
Typing Angle: 8°
Compatible System: Support Windows & Mac
Battery: 5000mAh (2500mAh*2)
Rolling rate: 1000Hz (Wired), 125Hz (Bluetooth, 2.4G)
Front Height: 16.9mm
Badge: Red copper
Add on: PC, Alu plate without flexcuts
Plate
FR4 material
1.6 mm thickness
Without flex-cuts
Support ANSI or ISO layout
Support stepped caps lock
Support 7U, 6.25U spacebar
Compatible with PCB stabs
PCB
Hotswappable
1.6 mm thickness
Without Flex-cuts
PCB mount stabs compatible with tri-mode PCB (single mode PCB only compatible with Plate mount stabs )
Support ANSI & ISO layout
Support ANSI/ISO Layout
Support QMK/VIA
No per-key RGB
6. Inside the box
Aluminum top case * 1
Aluminum bottom case * 1
copper badge * 1
FR4 Plate * 1
Hot-swappable PCB * 1
Type-C cable * 1
Screw bag * 1
Foot pad * 4
Plate stabs
Packaging box * 1
7. Vendor Information
Worldwide: Unikeys (
Instock drop date: Before November 15th
Join our Discord server to get the instock drop notification:
Last Edit: Thu, 06 November 2025, 15:26:27 by DashanYYY
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
(Moderator:
Signature
