Author Topic: [GB] Class100---Fullsize board inspired by DEC VT220-LK201  (Read 23051 times)
Offline Totoro
« on: Mon, 08 December 2025, 04:16:58 »
Hi community! This is MM Studio and we r bringing u our newest GB: Class100
Brief intro: Fullsize keyboard with Solenoid/Buzzer, PC legend strip with OG VT220-LK201 look design. Replaceable 3u top badge.
DEC VT220-LK201 with PC legend strip version:
Introduction
The Class100 returns to the roots with a classic 100% full-size layout.
We've designed a modular top-right section that houses a 3u brass enamel badge,
which can be easily swapped out for three functional 1u keys.
Features a PC (Polycarbonate) accent strip with legend inserts,
inspired by the LK201, also with classic 3 indicator leds on old full size board.
As always, MM Studio's classic solenoid and buzzer are integrated into the Type-C daughterboard located under the top strip. The daughterboard features a custom orange spray coating, designed to faintly peek through the translucent PC strip for a layered visual effect.
Utilizing the PC material's light diffusion, the Legend Strip is backlit by a full-length RGB strip and features 3 classic indicator lights.
The bottom weight design draws direct inspiration from the cover art of the classic VT220 Reference Guide—a visual motif we have also carried over to the Class 100’s packaging and instruction manual.
(Please note that the enamel infill color on the weight will be adjusted for the final Group Buy units. While the prototype photos show a bright red, the mass production units will use a Deep Burgundy (Original Dark Purple-Red) to match the original color.)
Class 100 utilizes a classic Isolated Top Mount system.
We use custom-molded silicone socks, which are then secured using shoulder limit screws. This ensures consistent alignment without over-stiffening the typing feel.
And also the design allows for flexibility. You can choose not to install all the screws, allowing the silicone caps to act as a Gasket Mount for a softer experience.
For those who prefer a livelier spacebar, you can remove the mounting screws specifically on either side of the spacebar to adjust the local flex and acoustic feedback.
GB info:
Colors:
(There will be an extra pair of black color feets for GB units)
(The Industrial Grey proto is not finished yet, plz refer the color to pantone Cool Grey 10C)
Plates:
Though there is no plate less build option, we wanna introduce 2 different plate design to replicate the signature plateless typing experience: Alu Hafl-plate and Alu Bikini-Plate
Special OG color Dyed PC plate and others
PCBs:
Solder and Hotswap PCB shares the same layout (Discussing add ALPS support to Solder pcb)
Specs:
Keyboard Size: Check following pic
Weight:~4.05kg built (PC plate)
Typing Angle: 7°
Mounting method: Isolated Top Mount
PCB:QMK-VIAL
Case material: 6063 Aluminum
Inner weight material : Brass with antioxidant treatment
Back weight material : Brass with antioxidant treatment
Details:
Keyboard Kit Price: Starts from 370$ (320$ Barebone)
Details plz check through our web page:
https://www.mmkeyboard.com/collections/class100
GB Date:  17th Dec 2025 to 7th Jan 2026
GB method: Unlimited GB
Est order fulfillment / ship to vendors: 4-5 months after GB ended
Vendor list:
TBA
Join our discord to get newest info!  https://discord.gg/JwhcamtBGS
« Last Edit: Tue, 09 December 2025, 02:54:02 by Totoro »
Re: [GB] Class100---Fullsize board inspired by DEC VT220-LK201
« Reply #1 on: Mon, 08 December 2025, 12:41:22 »
Will Divinikey be the US Vendor like usual?
Offline Baron
  • oops its me
« Reply #2 on: Mon, 08 December 2025, 20:26:29 »
will there be any options besides PC for the strip at the top?
Offline Totoro
« Reply #3 on: Mon, 08 December 2025, 23:50:12 »
We discussed this and communicated with the factory, an ano-ed alu top piece with bout 50 moq (estimated from our past GB) will cost bout 60-70$ and we r afraid that few will take this price. But will take a consideration of this and make a small ic in the discord community.
Offline FoxandFoundry
« Reply #4 on: Thu, 18 December 2025, 22:21:01 »
This looks awesome.
Will there be an option to purchase a hard-shell case?
« Last Edit: Fri, 19 December 2025, 00:13:56 by FoxandFoundry »
Offline soundstage
« Reply #5 on: Tue, 23 December 2025, 10:04:39 »
No storage or carry case?
Offline abcgel
« Reply #6 on: Sat, 17 January 2026, 20:59:06 »
Is it still available for pre-order?
Offline Jarhead
« Reply #7 on: Mon, 09 March 2026, 14:19:00 »
Any plans for EC compatibility?
Offline P.P
« Reply #8 on: Mon, 16 March 2026, 10:25:56 »
i like this vintage 2000 style!
