Author Topic: [GB] Enso-E by Clever | Dec 8 - 22  (Read 159302 times)
Offline GarrettSucks
  • All project timelines at at timelines.omnitype.com
    • Omnitype
« on: Mon, 08 December 2025, 12:07:27 »
THE ENSO-E GROUP BUY
DECEMBER 8 – 22, 2025
A sculptural, semi-transparent split keyboard blending CNC precision with organic form.
WHAT IS ENSO-E?
Enso-E is a split, sculptural keyboard inspired by Zen minimalism and the concept of the ensō — a hand-drawn circle symbolizing balance, simplicity, and enlightenment. Designed for comfort and clarity, it blends organic curves with precision-milled geometry to create a natural typing experience that feels both grounding and refined.
Every detail, from the smooth top contour to the subtle symmetry between halves, reflects a pursuit of functional harmony and timeless form.
FULFILLMENT TIMELINE
Estimated Delivery: Q3 2026
REGIONAL VENDORS
USA: Omnitype
Canada: Desk Hero
UK: Prototypist
EU: Oblotzky
China: KBDfans
Singapore: ktechs
Australia: Keebzncables
EDITIONS
STANDARD ENSO-E — Unlimited During GB
Four launch colorways available globally through all vendors:
    SAND — $519.99
    Accent Border: Copper (patina’d + sealed)
    Top Housing: Smoke Injection-Molded PC
    Plate: Aluminum Anodized Silver (MX) / Stainless Steel (DynaCap)
    Bottom Housing: Aluminum Sand Powdercoat
    Weight: Copper (sealed)
    STONE — $519.99
    Accent Border: Aluminum Anodized Light Grey
    Bottom Housing: Aluminum Stone Powdercoat
    Weight: Stainless Steel
    BOTANICAL® — $449.99
    Accent Border: Aluminum Anodized Dark Green
    Top Housing: Clear Injection-Molded PC
    Bottom Housing: Aluminum Anodized Light Green
    Weight: Aluminum Anodized Dark Green
    SNOW — $449.99
    Accent Border: Aluminum Anodized Silver
    Bottom Housing: Aluminum E-coat White
    Weight: Aluminum Anodized Silver
    [/list]
    Product Page → https://omnitype.com/products/enso-e
    TITAN — Special Limited Edition / 50 Units / $1,549.99
    The Titan is the most exclusive and uncompromising edition of the Enso-E. Every CNC-machined metal component, including both plate offerings, is crafted from premium titanium alloy for exceptional rigidity, resonance, and longevity.
    Its top shell is milled from a solid block of acrylic, meticulously hand-polished to a crystal-clear finish, then dyed to achieve a rich brown-amber hue.
    Limited to just 50 units via preorder, each Titan is individually serialized and undergoes a rigorous multi-step QC process, including detailed inspection by Clever and Omnitype to ensure the highest standards of precision and craftsmanship.
    A true collector’s piece, the Titan stands apart from the rest.
    LIMITED EDITION — 50 UNITS AVAILABLE / FCFS
    Product Page → https://omnitype.com/products/enso-e-titan-edition
    WHAT’S INCLUDED IN EACH KIT
      [] Border Accent
      [] Top Housing
      [] Plate
      [] Two 2u/1u Plate Islands
      [] Two 3u Plate Islands
      [] Bottom Housing *
      [] Weight *
      [] Hybrid EC/MX PCB
      [] USB Daughterboard *
      [] Daughterboard Ribbon Cable *
      [] Pogo Pin Daughterboard *
      [] Silicone Pogo Pin DB Grommet Thing *
      [] Silicone Gasket Socks
      [] Silicone Border Gasket
      [] Silicone Press-fit Feet
      [] Custom Magnetic Torx Screws
      [] Bottom Mount Torx Screws
      [] Torx Weight Screws *
      [] Cleaning Cloth
      [] Custom SUS304 Clever Chopsticks
      [] Instruction Manual
      [] Authentication Card
      [/list]
      * Pre-assembled components
      [/size]
      GROUP BUY DETAILS
      GB Window: December 8–22, 2025
      Unlimited Units: Standard Edition
      Limited Units: Titan Edition (50 units, FCFS at Omnitype)
      Fulfillment Estimate: Q3 2026
      Worldwide Vendors: Listed above
      COMMUNITY + UPDATES
      Join the Clever community and follow development updates, behind-the-scenes progress, and production notes:
      https://discord.gg/vWwArGE6Cm
      Thank you for your continued support.
      We can’t wait to see your Enso-E builds.
        • Omnitype
      Re: [GB] Enso-E by Clever | Dec 8 - 22
      « Reply #1 on: Mon, 08 December 2025, 12:07:45 »
      Reserved. Posted for Clever because he can't lol
      « Reply #2 on: Mon, 08 December 2025, 12:17:45 »
      Approved :thumb:
      Offline tavapataor
      « Reply #3 on: Mon, 08 December 2025, 12:32:45 »
      Beautiful board. Does "[f]our launch colorways" mean that the standard board will be available for purchase somehow from the various regional vendors following the fulfillment of the group buy?
      Offline Adelscott
      « Reply #4 on: Mon, 08 December 2025, 14:16:56 »
      no split left shift, no buy
      Please think about ISO users, add a split left shift to your "alice style" keyboards
      Offline dom
      • allergic to hypocrisy
      « Reply #5 on: Sat, 13 December 2025, 19:01:36 »
      To anyone considering the Titan version:
      Be honest with yourself.... it won’t make you feel special or validated. The “exclusive,” “collector’s piece,” and “rigorous multi-step QC” framing is doing the selling. If you like the board, buy the cheaper version and keep the rest, invest it, save it, or spend it on someone you care about.  :-*
      GLWGB
      Offline pseudonym
      « Reply #6 on: Sun, 14 December 2025, 09:49:56 »
      I don't get it from the pictures... what size are the spacebars?
      Online ivanh98
      « Reply #7 on: Sun, 14 December 2025, 12:04:28 »
      pictures are 3u spacebars but it supports 2u + 1u(1u on the inside towards the center of the board)
      Offline nathanchere
      « Reply #8 on: Mon, 20 July 2026, 05:16:59 »
      I guess this means even less chance of getting updates here than usual.
      Offline nathanchere
      « Reply #9 on: Thu, 08 October 2026, 14:22:42 »
      I'm tired of supporting ****tily-run GBs which go past delivery date without so much as an update.
      Last mention on discord anncouncements was in June saying still on track for Q3.
      Shouldn't need to go on a scavenger hunt to find updates in random comments in a sea of discord chat.
      How hard is it to have the basic courtesy of updating especially when running over?
