Author Topic: PSU problem.  (Read 6817 times)
Offline sam113101
PSU problem.
« on: Sun, 07 November 2010, 22:39:03 »
My comp was VERY noisy, so I told myself it was the time to remove the dust. To my surprise, there wasn't much dust on the CPU fan. I blew some canned air into the PSU. Now, the noise is terrible, it's far worse than it was. Why is my PSU acting like that*?
Hoping to hear from you again, your dearest friend, sam113101.
Offline 8_INCH_FLOPPY
PSU problem.
« Reply #1 on: Sun, 07 November 2010, 23:05:46 »
Try *unplugging* the psu, removing the cover and vacuuming the inside out.  PSUs fail when too much dust builds up and they overheat.  Your PSU has a fan.  You probably blew dust into it.
I had been getting BSOD crashes intermittently for several months.  Eventually, they got so bad that I pulled the psu out, opened it up, and found a thick layer of dust covering everything.  It's been about three months since I cleaned it out, and I have not experienced a single crash.
I'm not saying that is going to happen to you.  I'm just recommending you take action to prevent it.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline Rajagra
PSU problem.
« Reply #2 on: Sun, 07 November 2010, 23:15:38 »
Using canned air on a fan can cause it to spin too fast causing damage. Bit like revving a car engine in neutral with no load to balance the forces.
Might be temporary though. If you can remove the fan you can whack it against a table to try and reseat the parts.
Having said that, if it was noisy and relatively dust-free before, it may have been partially seized for some time. Time to replace the fan or PSU.
Offline Phaedrus2129
PSU problem.
« Reply #3 on: Sun, 07 November 2010, 23:36:18 »
What is the brand and model of the power supply in question?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Ekaros
PSU problem.
« Reply #4 on: Mon, 08 November 2010, 01:18:18 »
Yeah, got dead PSU and ended up replacing it with a new one and the case at same time. Seems like they are upgrading their desings. This one has own intake for PSU and dust filter for it. PSU is only doing it's own cooling. Unlike my old case where it was only exit went too...
Heat can also kill them, still cleaning the PSU might help, but leave it on table for sometime if you are going to clean the inside just in case...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline ch_123
PSU problem.
« Reply #5 on: Mon, 08 November 2010, 04:22:39 »
If you're opening a PSU, be as careful as hell that you don't fry yourself.
I never knew airdusting fans could damage them, it would explain why the fan in my Thinkpad is ****ed though.
Offline chimera15
PSU problem.
« Reply #6 on: Mon, 08 November 2010, 04:37:21 »
If it's making a noise it's most likely the cooling fan, not the psu itself.  Fans wear out their bearings, unless they're bearingless like on most laptops.  You can usually replace them with standard case fans.  I've had a number of constant running systems wear them out.  Usually takes about 5 years of constant running or so.  I've done a few replacements of the fans.  Usually only costs $5-10 at most.  They even sell replacement fans that are sold as case fans that will work on most at Best Buys.
« Last Edit: Mon, 08 November 2010, 04:40:51 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline zefrer
PSU problem.
« Reply #7 on: Mon, 08 November 2010, 05:48:12 »
Yeah what chimera said. If it was making a noise before then the fan has probably died/about to die. Can be replaced pretty easily, as long as your PSU is not about to go as well.
Offline Rajagra
PSU problem.
« Reply #8 on: Mon, 08 November 2010, 06:04:34 »
If you do replace the fan, may as well get a quiet one. Even if it costs a bit more it's likely to be much better quality than the cheaper ones.
Offline EverythingIBM
PSU problem.
« Reply #9 on: Mon, 08 November 2010, 09:00:47 »
Quote from: ch_123;244148
Interesting, I shoot compressed air in my fans all the time; never had a problem with any of them (of course usually they're all turned off, would be kind of silly blowing air into a running fan).
Offline Fwiffo
PSU problem.
« Reply #10 on: Mon, 08 November 2010, 12:05:16 »
It may be that the fan in the PSU was already bad and noisy (considering the whole computer was noisy and it didn't seem to be caused by some other fan) and that when you blew out the dust it just made an already broken fan worse. If the fan is broken the whole PSU may be on its way out.
You can call me... Keyboard Otaku... or not quite...
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
PSU problem.
« Reply #11 on: Mon, 08 November 2010, 14:51:27 »
Might be a good time to check whether the power supply is any good at all. If it's a lightweight cheapie, I'd rather toss it and install a quality new one (80+ certified, yadda yadda). Of course that assumes a reasonably modern computer that's heavy on +12V, not an oldie with CPU power from +5V.
80 mm fans normally last a fairly long time, definitely so if temperature controlled. A PSU that doesn't have a temperature-controlled fan is either very old (>10 years) or cheap trash.
And yes, it's a good idea to remove mains power a few minutes (at least) before opening a PSU. They normally have bleed-off resistors so the high voltages will go down relatively quickly, but still better safe than sorry. DC voltage after the primary-side rectifier can be up to about 385 V, so the filter capacitor can bite quite a bit.
PSU problem.
« Reply #12 on: Mon, 08 November 2010, 15:09:09 »
He hasn't posted again.
I'm the PSU guru. Don't know much about fans, but I can tell you if it's a cheap Chinese piece of horse **** or not.
Offline Ekaros
PSU problem.
« Reply #13 on: Tue, 09 November 2010, 10:06:54 »
Quote from: Phaedrus2129;244389
I went overkill and went for 650W Corsair TX, freaking 89€... And running it in 4/6 year old computer. But atleast I now got something which run my next comp for 5-10 years...
« Last Edit: Wed, 10 November 2010, 10:14:04 by Ekaros »
[SIGPIC][/SIGPIC]
Offline D-EJ915
PSU problem.
« Reply #14 on: Tue, 09 November 2010, 19:46:27 »
Don't bother trying to replace the fan, you'll have to solder more than likely.  Get a nicer aftermarket or OEM PSU instead.
Quote from: Ekaros;244615
I went overkill and went for 650W Chieftec TX, freaking 89€... And running it in 4/6 year old computer. But atleast I now got something which run my next comp for 5-10 years...
I've used seasonic OEM ones in my new computers and they have worked great for me so far.  SS-650HT for my quad and SS-860HT for my octo
« Last Edit: Tue, 09 November 2010, 19:49:26 by D-EJ915 »
Offline ch_123
PSU problem.
« Reply #15 on: Wed, 10 November 2010, 04:27:06 »
Some (up to about 650W) Corsair PSUs are just rebranded Seasonics, which is why everyone loves them.
