Author Topic: [IC] SA TI914 - Y'all like Texas?  (Read 9859 times)
Offline mcmcmc
« on: Tue, 23 December 2025, 11:32:39 »
SA TI914
Hey SA lovers,
This keyset is inspired by the Texas Instruments 914 keyboard. While browsing Deskthority looking at vintage boards, I stumbled upon this absolute gem.
Unfortunately, I find little information available about it, which makes it feel even more special to me (If you know more about this keyboard, please share :)).
You can check out more photos of the original keyboard here.
IC Form
Details
Material: ABS
Legends: Doubleshot
Colors: GKH, GTR, RDD, VDQ, YY
Row: R1, R1, R2, R3, R4, R3
Kits
Renders
TKC1800 by TheKeyCompany
Glare65 by Glare
Zoku by Flybeck
Socials
Discord
Instagram
Thanks
You for reading
XMIT for documenting the board and images
« Last Edit: Tue, 23 December 2025, 11:43:44 by mcmcmc »
Offline madmax13
Re: [IC] SA TI914 - Y'all like Texas?
« Reply #1 on: Tue, 23 December 2025, 11:33:38 »
GLWIC! Always happy to see new SA!
Designer- MTNU Welles, GMK City Pop Neue, DSS Distortion 40s, GMK Distortion, and SA Motorsport Selectric.
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #2 on: Tue, 23 December 2025, 11:38:45 »
Always great to see more SA! GLWIC!
Offline pixelpusher
« Reply #3 on: Tue, 23 December 2025, 11:52:22 »
Big fan of SA.  The inspiration board looks like the alphas are almost white.  I think they just look gray from the lighting.  Because I already have quite a few SA sets with a gray similar to this, I would be more interested in a lighter shade like GVA, if not just white WFG, WGE
something to make it look like an aged white, not gray
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #4 on: Tue, 23 December 2025, 15:09:26 »
Based on the photos of the original, I bet Signature Plastics was the keycap manufacturer. Although the switches aren't MX, it looks like uniform-profile R3 SA. If so, they might have the tooling for original-legend function keys.
Offline Baron
  • oops its me
« Reply #5 on: Tue, 23 December 2025, 16:54:01 »
very exciting, i do wish just two more keys were added to the base set to allow for a fully grey 60%, could look very sharp
Offline mcmcmc
« Reply #6 on: Mon, 29 December 2025, 10:45:30 »
i can do that :thumb:
hmm, interesting thanks for pointing that out. i will look into that.
i feel that the colors are close to original, at least from the images i saw. i suspect that it's the lighting, but i will check again.
On another topics, happy holiday everyone. :D
Offline GMK_Andy
    • GMK
« Reply #7 on: Sat, 03 January 2026, 11:49:37 »
Very nice industrial looking set!
Offline tavapataor
« Reply #8 on: Sat, 03 January 2026, 16:38:00 »
I love this. I’m trying to decide if this would look awesome or cringe with Touchstone.
« Reply #9 on: Mon, 05 January 2026, 10:50:35 »
These were not produced by Signature Plastics, they were made by Micro Switch. Comptec (SP has their tooling after a buyout in 2001) did not make these keycaps. I'm actually not sure if Comptec was active in keycaps in the mid 1970s. I was not able to find any activity from them before 1982 when the Wyse and BBC keboards were made. (They were founded 1973 but just did normal injection molding at first).
At first I thought they were the same, but they are actually different if you look closely.
The very top of the keycaps on SP SA has slightly more area than these, and the top is less dished. The top is more rectangular because of this.
The bottom edges are curved (Micro Switch come to a point).
Surface texture is also different
The legends are also different, but this is harder to see.
Fun fact: SP has the stem molds to produce new SA keycaps that fit Micro Switch stems. This makes sense as the profile was designed for older keyboards.
Details about the keyboard: it features Micro Switch SW keyswitches and is from 1975. The part number is 102SW11-1 and I was not able to find any other pictures of it for my Micro Switch photos and data archive.
This keyboard is notable for featuring backlit SW switches which are very uncommon. The output to the terminal is probably "parallel ASCII" which was common for keyboards in the early-to-mid 1970s. The Apple 1 for example could use several different keyboards (one of which was a Micro Switch unit) because it took this input, and other Texas Instruments keyboards used it as well. This is not confirmed but if XMIT posts more photos of the PCB I could determine more information.
315728-0315730-1
I tried to attach some pictures. Sorry for the photo quality, I was not focus stacking my macro photos at the time I took these.
« Last Edit: Mon, 05 January 2026, 11:07:08 by dorkvader »
Offline mcmcmc
« Reply #10 on: Fri, 09 January 2026, 13:53:31 »
Obviously awesome!  :p
