Author Topic: I need help : creating the second iteration of the Switch Try Board.  (Read 1458 times)
Offline SirClickAlot
    • http://www.mrinterface.com
Yo folks,
I need help trying to set-up the second version of the Switch Try Board ( The first iteration was sent out today to Zefrer in England ).
For this second iteration I want to create a switch try board that makes it possible to see when a switch activates and when it de-activates.
For this I need 9 switches ( which I can supply ) and a piece of pcb , battery and LED attached to the pcb.
Since my skills are limited ( the first version of the Switch Try Board was crudely put together ) I need help with the creation of this second version. The way I see it is that I supply the 9 switches and some other member of this board puts it together in such a way that an LED is on when a key is pressed.
Don't worry about the costs : I will supply the euros where needed.
Regards.
[Succes is when you get what you want
Happiness is when you want what you get]
Optimize your interfaces : http://www.mrinterface.com
Currently using( not necessarily my favorite : I iterate over my collection many times ):
Filco White Majestouch Mx Brown DS White on Black.
Looking for : New and interesting interfaces. Working on :www.deskthority.net
