Author Topic: [IC] Haven65 XT | Instock, 65% XT  (Read 7790 times)
Offline papamao
« on: Sat, 10 January 2026, 12:29:44 »
Hello everyone,
This is Papamao again from Atelier Haven. I would like to introduce the instock addition to my Haven Series
Introducing: Haven 65 XT
Part I: Case Design
Comparing to previous Haven series keyboards, Haven 65+ uses patterns that mimics modern architecture envelopes to enhance how light and dark speaks on the surfaces of the keyboard.
The side profile is still clean, linear, floaty and multi material like modern architecture to ensure the keyboard always look different and yet beautiful under varying lighting environment.
The "Dragon Scales" on the back of the Haven 65+ is not only fabulous in its outlook, but also feels good to touch.
The type-C port side of the keyboard has enhanced volumetric design through the use parametric design, createing multiple different angled surfaces. so that this part of the keyboard is more dynamic under different lighting environment
The slim and volumetric side profile is always the key design feature of Haven keyboards. The use of gray space, just like what many modern architecture are designed, makes space for the embient light to spread out to the desktop while lights up the sleek side profile.
The front badge uses the "dragon scale" design as well and shines with the light bar in the middle of the badge.
Part II: Typing Experience
Front Height:16.7 mm
Rear Height: 33.0 mm
EKH: 20.8 mm
Angle: 8.5 degrees
Weight: 2.23kg
Haven 65+ uses plate-gasket along with black core 1.6mm pcb. Due to the lower front height, even though the gasket is used on the plate, you will still expect a more top-like supportive, hard and consistent typing experience.
What is included in the kit: Keyboard bag, assembled cases, one metal front badge, two pieces of PC block, one PCB, one plate, one set of ixpe foam, 3.5mm poron and bottom case foam, 16 pieces of silicon socks, one set of daughterboard plus magnetic dongle, three pairs of silicon feet, extra top case screws
Part III: Colorways and Pricing
Anodized Aluminum Deep Navy Case+Copper Middle Weight+Copper Weight (460$)
Anodized Aluminum Burgundy Case+Copper Middle Weight+Black PVD SS Weight (480$)
Anodized Aluminum Silver Case+Copper Middle Weight+Blue PVD SS Weight (480$)
Anodized Aluminum Silver Case+Copper Middle Weight+Silver PVD SS Weight (480$)
Anodized Aluminum Gray Copper Case+Bronze Highlight+Copper Middle Weight+Copper PVD SS Weight (500$)
Anodized Aluminum Ice Blue Case+Silver Highlight+Copper Middle Weight+Silver PVD SS Weight (500$)
Anodized Aluminum BlackCase+Copper Highlight+Copper Middle Weight+Black PVD SS Weight (500$)
Electrophoresis Aluminum White Case+Blue Highlight+Copper Middle Weight+BluePVD SS Weight (510$)
Part IV: Renders and Photography
Render
Photography
Part V: Sale Format and Links
Instock FCFS, ship from China directly
Sell date: TBA, expect 01/14/2026
Discord
Vendor : Keyspensory
Review
Typing Test
Thank you for your time of reading.
« Last Edit: Sat, 10 January 2026, 12:41:38 by papamao »
Offline papamao
Re: [IC] Haven65 XT | Instock, 65% XT
« Reply #1 on: Sat, 10 January 2026, 12:30:26 »
reserved
Offline DirtyGingy
« Reply #2 on: Sat, 10 January 2026, 12:35:39 »
I wouldn't have expected in stock. Cool design and fits well with the other haven boards.
« Reply #3 on: Sat, 10 January 2026, 12:55:49 »
We need an FRL XT after this one for sure
Offline JasonIStokes
« Reply #4 on: Mon, 02 February 2026, 22:10:00 »
Thank you for sharing! I agree in the post
Edit by ultimate tic tac toe a day ago
« Last Edit: Thu, 05 February 2026, 20:47:51 by JasonIStokes »
