Author Topic: [IC] SharXTv2 - Top Mount 65XT  (Read 5029 times)
Offline fergstetal
« on: Fri, 16 January 2026, 21:42:46 »
SharXTv2
IC FORM
Discord
Specifications
XT 65%
8 Point Top Mount
9° Typing Angle
18mm Front Height
~2kg (4.4lb) Unbuilt
Sound Test Playlist
GB Info
At 10moq, I am expecting price to be around $380 per unit (including one PCB and shipping from manu)
While I don't have a specific GB date in mind, I would like to wait until after CNY to avoid delays.
Color choices are expected to be Pantone 2727 C, 2455 C, and 875 C.
All units will have a silver aluminum plate & bottom, with your color choice only affecting the top half.
I will make plate files available for those that would like to have one cut from anything else.
PCBs will be offered in both solder and hotswap, expect them to be about $30-35 each for extras.
GB units will not be from the same manufacturer as the prototype, as I am very disappointed with the machining quality.
Prototype Pictures
Thank you, Ducky, for the wonderful pictures <3
If I've missed anything, please let me know and I'll update the post/make the info available.
Thank you for taking the time to check out this post. Please fill out the IC form if you have the time <3
« Last Edit: Fri, 16 January 2026, 22:18:32 by fergstetal »
Offline DirtyGingy
Re: [IC] SharXTv2 - Top Mount 65XT
« Reply #1 on: Mon, 19 January 2026, 15:33:19 »
I'm surprised you're aiming so low on the MoQ. This seems pretty nice.
Though, I did accidentally read the name as "shart" at first...
« Reply #2 on: Mon, 19 January 2026, 15:43:53 »
Would be cool getting this in XT FRL TKL too after this project
Online xjack312
« Reply #3 on: Mon, 19 January 2026, 17:48:35 »
we're sharting today :D
Alice enjoyer
Offline fergstetal
« Reply #4 on: Mon, 19 January 2026, 18:20:35 »
I'll be fulfilling the GB from home, so I don't want to end up overwhelmed and take forever to ship, I'd be willing to go to 20 or so units total. I figured it was a safer bet to give the 10moq price in case 20 isn't reached :)
(also, I've lovingly called it shart through most of the project's life <3 )
Offline Raie_de_Boule
« Reply #5 on: Wed, 28 January 2026, 15:15:07 »
Well I'm not this much into 65 or XT.
But this is pretty interesting.
Offline Natetypesfast
« Reply #6 on: Wed, 28 January 2026, 16:55:34 »
need more 65xts.  I like it
