Author Topic: [IC] PBTfans Maguro  (Read 50395 times)
Offline sososoya
[IC] PBTfans Maguro
« on: Sat, 17 January 2026, 02:56:18 »
PBTfans Maguro
Join Discord Server for updates XD
Intro
Long time no see, this is Soya, and today I'm bringing you the latest news about Maguro.
Inspiration
I once waited in line for 5 hours to eat at a rotating keycaps restaurant...
The crystal-clear keyboard, covered with tuna red meat caps, reflects an attractive luster on the conveyor belt moving at a speed of 8 centimeters per second.
Actually, I prefer tuna to salmon. :thumb:
Renders
Due to the influence of environment and lighting, the rendering color may differ from the actual object to some extent. Please refer to GMK WS1 for the white color code of the keycaps.
The injection molding holes of the model are only for design preview and do not represent the final effect.
Kitting
There may be changes, please refer to the GB post for accuracy.
Contact
If you are interested in this set, why not join my Discord server? I will post updates on the latest progress of TUTKEYS C.C.C.C from time to time there. (I will communicate with you using Google Translate XD)
Discord server:https://discord.gg/cFXNcGUbcf
Disclaimers
The renders may differ visually from the final product. In case of any discrepancy between the renders and the final product, the final product shall prevail.
Offline sososoya
Re: [IC] PBTfans Maguro
« Reply #1 on: Sat, 17 January 2026, 03:15:03 »
For Update :p
« Reply #2 on: Sat, 17 January 2026, 14:10:16 »
Is this PBTFans ABS or PBT?
Offline spidey3
« Reply #3 on: Sat, 17 January 2026, 20:14:54 »
Looks great!
Is there an IC form to submit?
Offline P.P
« Reply #4 on: Sun, 18 January 2026, 07:11:52 »
Really! Inspiration comes from everywhere!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #5 on: Mon, 19 January 2026, 16:42:48 »
Offline XORMAMMU
« Reply #6 on: Mon, 16 February 2026, 12:50:06 »
Looks great! But what if you add 6 R1 keys from the Akami kit to the R2 row too. And make 3 keys on the R3 row in Emotes kit too, this would greatly simplify the implementation of a 40% keyboard with an emoji alpha layer.  I'll definitely buy myself a set of this red agar mini. Thank you.
Offline NihonCK
« Reply #7 on: Mon, 16 February 2026, 17:30:13 »
https://kbdfans.com/collections/pbtfans-ic/products/pbtfans-maguro
says PBT but their transparent keys have always been ABS like on the white enter key, spacebar, arrows, and some of the red r1 keys at the bottom of the kit look like the transparent abs with the presentation of the renders. Same for the "Akami" kit with regard to the white keycaps
Offline dvorcol
« Reply #8 on: Mon, 16 February 2026, 18:09:07 »
Thanks! KBDfans' IC wasn't out yet when I asked.
Offline dvorcol
« Reply #9 on: Tue, 25 August 2026, 16:18:21 »
This set is in stock at KBDfans. There are a couple other vendors as well.
   Global: KBDfans - https://kbdfans.com/products/pbtfans-maguro
   US: Divinikey - https://divinikey.com/products/pbtfans-maguro-keycaps
   UK: MechMods
   SEA: Maxgaming
