Author Topic: [GB] NV-70 | 70% layout board inspired by Hyundai N Vision 74  (Read 12962 times)
Offline keybay.tech
    • KEYBAY
« on: Sun, 18 January 2026, 19:16:21 »
NV-70 by GDK Lab
Hello Friends!
This is Chester from KeybayTech. I would like to introduce a 70% keyboard: The NV70 by GDK Lab.
GDK Lab Discord | KeybayTech Discord | Landing Page
NV-70 draws its inspiration from Hyundai's 2022 concept car - N Vision 74.
A masterpiece that perfectlyblends retro charm with futuristic innovation. With its timeless silhouette and aerodynamic lines, the N Vision 74 redefined the direction of modern automotive design. Guided by the same design spirit, the NV-70 was born.
Fusion Beyond Boundaries
During the creative process, we knew that simply transplanting automotive elements into a keyboard would never work. After all, cars and keyboards differ vastly in both function and form - each serving entirely different purposes and experiences.
To make the two worlds blend seamlessly, the key lies in extracting the most iconic, soulful elements of automotive design and reimagining them through the lens of a keyboard. By integrating these details with the product’s core functionality, we allow the keyboard to retain its true essence while gaining a distinctive personality that sets it apart.
On the front layout, we reimagined the traditional 70% configuration by raising the numpad section and introducing a divider between the main area and the numpad. This adjustment creates a more balanced and visually harmonious front.
We also modified the nav cluster to allow for a swappable, customizable numpad zone - adding a new layer of creativity and playability to the overall design. You can use it as a FRL TKL or transform the right side into a numpad or other macro / function keys.
We also drew inspiration from the bold, futuristic aesthetic of Tesla’s cybertruck to design the TKL addon, incorporating automotive grille motifs and creating a mechanical, forward-looking design.
The Weight
NV70 has two different weights: Machining - Mark SS / Mirror SS
Flexible Right-side and Top case layout
The right-side cluster on the NV70 isn't just for function keys - it can also be used as a numpad, or remapped into anything you want via VIA.
Whether for work or everyday use, it will be your best keyboard.
You can also use removeable WKL blockers to get either WK or WKL layout.
Configuration
In terms of layout, both hot-swappable and soldered PCBs are supported, offering compatibility with split backspace, split left shift, split right shift, and ISO layout. It also allows switching between the right-side nav cluster and the pad zone, providing greater flexibility for different user preference.
Front Height: 16.8mm (without feet)
Typing Angle: 8°
Dimensions: 354.6 x 113 x 32mm
Weight: 1.75kg fully built
Tri-mode Battery: 5000mAh
Colorways:
Anodized Gunmetal Gray | Anodized Silver
Anodized Dark Gold | Anodized Lilac
Anodized Light Pink | Spray-coated Elephant Gray
Spray-coated Yellow | Spray-coated Flash Black
Group Buy info:
Group Buy opens: Jan 25th 2026
Group Buy ends: Feb 10th 2026
Estimated Fulfillment: Q2 2026 or earlier.
Pricing:
Starting $150 USD
Package Content:
1 x NV70 Barebone
1 x Plate of your choice
1 x PCB of your choice (VIA/QMK support)
1 x Foam kit
1 x Gasket Silicone accessories
1 x Screwdirver
1 x Type-C cable
1 x User manual
Vendors:
North America:KeybayTech
Singapore:ktechs.store
United Kingdom:ProtoTypist
Europe: Deltakeyco
Korea:Geon Works
Japan:Basekeys
Australia:KeebzNCables
Indonesia:KeebsMark
Southeast Asia:Aiglatson Studio
Vietnam: The Keebs Store
Creators reviews & Posts
Alexotos: Coming Soon
Scooped Bar: Coming Soon
Captain Sterling: Coming Soon
Mikey Types
Moru: Coming Soon
Anhecdotes: Coming Soon
Dango.niko: Coming Soon
KeybayTech: Coming Soon
Mango.keebs: Coming Soon
Geon: Coming Soon
Links:
GDK Lab discord
Keybay Tech Discord
Landing page
Thank you for stopping by! Have a wonderful day!
« Last Edit: Tue, 20 January 2026, 11:03:00 by keybay.tech »
Offline meowoofun
  • Design Critic
Re: [GB] NV-70 | 70% layout board inspired by Hyundai N Vision 74
« Reply #1 on: Tue, 20 January 2026, 13:18:01 »
$150 starting? count me in!
Offline keybay.tech
    • KEYBAY
« Reply #2 on: Tue, 20 January 2026, 21:09:26 »
Yep!
Offline Raie_de_Boule
« Reply #3 on: Fri, 23 January 2026, 01:43:58 »
It's a yes
Offline awkwardpotato
« Reply #4 on: Wed, 28 January 2026, 08:55:38 »
Quite a beautiful board. Will the LED bars be addressable? If so how, saved in the firmware or controlled with an installed software?
Offline keybay.tech
    • KEYBAY
« Reply #5 on: Wed, 28 January 2026, 18:24:02 »
Hi, LED can be adjusted by VIA
Offline meowoofun
  • Design Critic
« Reply #6 on: Wed, 28 January 2026, 20:55:20 »
Just bought one in gunmetal grey! All in $160 no tax, free shipping for US! fk me I'll have to buy another before the GB ends.
