Author Topic: [GB] MASS 80 The Smartest Keyboard with Interactive Screen(GB live!)  (Read 4926 times)
Offline MILKYWAY KEYS
  • PBT keycap manufacturer
    • MilkywayKeys
Hello everyone, this is MW~
Milkyway known for keycaps, now stepping into kits with MASS 80. After 2+ years of R&D,
we present a TKL engineered around keycap-centric innovation, redefining modularity and interactivity.
Render video
Product Photography
If the screen appears slightly laggy, there’s no need to worry.
This is just an early demo. Our team is actively optimizing the software, and the final version will run at over 35 FPS,
resulting in smooth, fluid motion that’s clearly visible to the naked eye.
MASS 80 Product introdution
Feature Overview
Timeline
Re: [GB] MASS 80 The Smartest Keyboard with Interactive Screen(GB live!)
« Reply #1 on: Tue, 17 February 2026, 20:45:30 »
Approved :thumb:
Offline shansoft
« Reply #2 on: Fri, 20 February 2026, 03:17:07 »
Looks like buying from the vendor here doesn't come with keycaps like kickstarter?
