Author Topic: [IC] KeyKobo Shirasagi R2 Keycaps  (Read 7059 times)
Offline sososoya
« on: Wed, 04 February 2026, 08:25:15 »
Join Discord Server for updates XD
Intro
Hi all, this is Soya. It’s been a while – today, I bring you the interest check of Shirasagi R2.
Previous IC link: https://geekhack.org/index.php?topic=123420
Change
Shirasagi will be produced by KeyKobo, Cherry Profile, ABS double shot process, and the Hiragana character Alpha will use triple shot process.
Renders
Kitting
There may be changes, please refer to the GB post for accuracy.
Contact
If you are interested in this set, why not join my Discord server? I will post updates on the latest progress of Shirasagi from time to time there. (I will communicate with you using Google Translate XD)
Discord server:https://discord.gg/cFXNcGUbcf
Disclaimers
The renders may differ visually from the final product. In case of any discrepancy between the renders and the final product, the final product shall prevail.
Offline anson42
Re: [IC] KeyKobo Shirasagi R2 Keycaps
« Reply #1 on: Wed, 04 February 2026, 10:49:22 »
I like the design of this set but I passed on R1 because there was no minimum 4-key 40s support, let alone the 6-key or a 40s kit that I have come to appreciate in other Keykobo sets. Please consider adding 40s support into R2, into the base or in one of the child kits if you would like to pick up some more buyers.
Given the timing of most (if not all) KKB ICs, such feedback is usually already far too late for consideration but I have to at least try. Thanks!
Offline sososoya
« Reply #2 on: Wed, 04 February 2026, 13:00:30 »
Thank you for liking my design, but currently, keykobo has decided to produce this layout and cannot make any modifications. If there is a possibility of R3, I will include the 40S kit and possibly more kits
Offline anson42
« Reply #3 on: Wed, 04 February 2026, 16:09:16 »
Thanks. Here's hoping R2 does well and warrants a R3!
Offline julimma
« Reply #4 on: Tue, 10 February 2026, 20:07:40 »
Finally an R2!
Offline yoonelec
    • Naver Blog
« Reply #5 on: Thu, 19 February 2026, 01:20:56 »
The deep blue novelties look beautiful
It seems like the transparent keycaps were first introduced in R2, and they pair really well with the existing colorway
