Author Topic: Dead tactile pro 1.0  (Read 3848 times)
Offline cosmotic
« on: Mon, 08 November 2010, 22:55:53 »
I just killed my Tactile Pro (Strong Man SMK-POWER989) with ESD. Visual inspection of the capacitors and resisters and such doesn't reveal anything, I suspect the IC has been fried.
Any ideas on how to repair it? I can't find the IC anywhere. It looks like it might have been custom design for Strong Man by Alcor Micro.
Any takers on the dead husk (and all the delicious key switches it contains)?
-Charlie
Offline kps
« Reply #1 on: Tue, 09 November 2010, 08:55:31 »
Quote from: cosmotic;244505
What is it? Something like an AU9432?
Offline cosmotic
« Reply #2 on: Tue, 09 November 2010, 19:21:58 »
The text on the chip:
STRONG MAN
AU9432E2B-UAD
MJFK2-0001
0429
Offline kps
« Reply #3 on: Tue, 09 November 2010, 20:05:08 »
Well, the good news is that it's not a custom chip, or apparently even programmed, so if you find one, you should be able to swap it. The bad news is that it's 10 years out of date, so you probably can't find one.
How do you know ESD did it in? Were you shuffling across carpet poking people with the connector?
Does it look like this from here? If so, you might try jumpering the fuse(s) — the part(s) marked with an "F" — and see if it's just it/them that blew.
Offline cosmotic
« Reply #4 on: Tue, 09 November 2010, 20:15:52 »
That's it alright.
I know ESD did it in because it was working before I left for work and when I came home and touched the ctrl key to kill the screen saver/wake it up, there was a huge spark at the tip of my finger and the keyboard didnt work when the compute came back up.
Yes it looks almost exactly like that shot, except for the keys are white instead of black.
There look to be only two fuses, F7 and F8, would there be an F1 to F6?
Would it make sense to test the fuses with a multimeter to see if they have any resistance before shorting them or replacing them?
-Charlie
Offline cosmotic
« Reply #5 on: Tue, 09 November 2010, 22:13:49 »
I tested both fuses, they both briefly register resistance just as if I touched the two leads of the multimeter together. I don't think the fuses are blown.
-Charlie
Offline kps
« Reply #6 on: Tue, 09 November 2010, 22:25:54 »
Quote from: cosmotic;244803
Oh, it's unlikely the fuses helped, then. I thought it might have been something that happened when plugging or unplugging it.
Sure, it can't hurt. If they don't test zero or near zero resistance, try shorting them, but from what you've said, you're probably right in your first suspicion that the controller is toast.
I expect there are plenty of cheap rubber-domes of the same age that use the same controller, but I don't know of any in particular. The best I can suggest as far as identifying a suitable donor is that when connected to a computer the built-in two-port hub would probably have a USB Vendor ID of 0x058f and Product ID 0x9213, and the keyboard might have a USB Vendor ID 0x058f and Product ID 0x9472. But that is not a sure thing.
Offline Konrad
« Reply #7 on: Thu, 01 September 2011, 08:01:01 »
Sorry 'bout the necro.
A user in this DT thread just happens to be selling this exact OEM part, cosmotic.
[ Attachment Invalid Or Does Not Exist ] 25482[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 25480[/ATTACH]
« Last Edit: Thu, 01 September 2011, 13:15:12 by Konrad »
Offline simon_C
« Reply #8 on: Thu, 01 September 2011, 11:23:26 »
why dont you contact matias?
Offline Jim66
« Reply #9 on: Thu, 01 September 2011, 15:59:13 »
Quote from: Konrad;408668
(Attachment Link) 25482[/ATTACH]
(Attachment Link) 25480[/ATTACH]
'Tis I who is selling the board :). If you haven't already solved/binned the project, it's still available.
