Author Topic: [GB] Finn 60XT | GB February 25th, 2026 - March 30th, 2026  (Read 9691 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Thu, 26 February 2026, 16:30:53 »
Finn, a 60% XT Keyboard
The groupbuy for Finn, designed by Baucts, is going live February 25, 2026! Finn is a 60% keyboard with symmetrical XT columns and a sculpted front, side, and back profile. every angle is designed to be symmetrical and flow with each other. We have vendors for global vendors; you can find them below.
Vendors
NA: ClickClack
EU/UK: Prototypist
SEA: ktechs
CN: ktechs
CA: Mino Keys
AUS: SwitchKeys
Group Buy Date: 25th Feb - 30th Feb 2026
Estimaed Shipping Date: Q3-Q4 2026
Colorway Renders
noir
cobalt
ivy
eclipse
grape
blur
Features and Specs
-Polycarbonate or aluminum case
-Silicone gaskets (20A & 50A)
-Internal acoustic tuning
-QMK/VIA compatibility
-RGB under glow & indicator LED
-Friction fit feet
-Aluminum 6063 case
-351.66mm x 113.5mm
-7.5 degree typing angle
-Internal weight
-23.77mm EKH
-19.03mm front height
-1.4g aluminum unbuilt w/ brass internal weight
-WK & WKL
-Aluminum, polycarbonate, or polypropylene plate
-$420 @ 50 MOQ
Layout, Hotswap
Keep up to date on this and other projects on Baucts' socials
Discord server
Instagram
Twitter/X
Baucts' Website
Join ClickClack’s Discord for the latest updates, discussions, and questions:
Follow ClickClack's IG for other new projects:
Re: [GB] Finn 60XT | GB February 25th, 2026 - March 30th, 2026
« Reply #1 on: Thu, 26 February 2026, 16:32:05 »
Approved :thumb:
Offline baucts
« Reply #2 on: Fri, 27 February 2026, 10:58:09 »
reserved
« Last Edit: Fri, 27 March 2026, 21:26:46 by baucts »
Offline baucts
« Reply #3 on: Fri, 27 March 2026, 21:27:15 »
3 days left!
