Author Topic: Linux Mint Cinnamon Desktop Behavior Question  (Read 12084 times)
« on: Thu, 05 March 2026, 08:37:46 »
I recently built a new computer and installed Mint 22.3
However, in a variety of situations involving both programs and applets I cannot get to aspects of configuration that I need.
While the downloading and installations seem to go off without a hitch, when I attempt to make changes and adjustments, the selections seem to be dead or grayed out. Sometimes entire dropdowns show numerous choices but they are all grayed out !
It makes me feel like I have crippled or trial versions of these programs that need something else to come alive. It doesn't happen all the time, or even most of the time. I have run "update" many times, including this morning, so it is not that.
Help!  Thanks
- D Trump 2026-10-24
Offline Darthbaggins
  • PC Cannibal
Re: Linux Mint Cinnamon Desktop Behavior Question
« Reply #1 on: Sat, 25 April 2026, 22:47:26 »
might have to add those attributes via Sudo apt-get in terminal.  What are you attempting to add?  almost sounds like permissions are out of spec or driver base isn't mounting. (been a while since I used Mint)
Offline lumicore
« Reply #2 on: Wed, 27 May 2026, 07:14:13 »
Does it happen in specific apps only, or system-wide? Cinnamon sometimes greys things out if there’s a permissions/polkit issue, especially after fresh installs or hardware changes.
Offline alarmunreeve
    • strands hint
« Reply #3 on: Thu, 17 September 2026, 21:35:53 »
Would checking the driver first make sense here? The fact that the options are completely greyed out makes me wonder if it’s a permissions issue or something else.
