Author Topic: [IC] OF Studio – OF1 60% Keyboard Kit  (Read 12403 times)
Offline DashanYYY
    • Unikeys
« on: Wed, 25 March 2026, 14:26:17 »
316374-0
316385-1
OF Studio - OF1 60% Keyboard
Hi everyone,
We’re excited to share an early look at the OF1 Keyboard Kit by OF Studio. This project is entering the final stage before launch, and we’d love to gather feedback from the community.
Project Overview
The OF1 is a fully realized keyboard project with mass production already completed, positioning it as a low-risk group buy with a fast turnaround.
Unlike traditional GBs, this is closer to a ready-to-ship model, with only final configurations remaining before launch.
Keyboard Specs
Specifications
Layout: 60% (WKL / HHKB / WK)
Typing Angle: 8°
Front Height: 17.17 mm
EKH (Effective Keyboard Height): 22.69 mm
Case Weight:
Brass bottom: 1944 g
Aluminum bottom: 1192 g
Mounting: Top Mount / O-ring Mount
PCB Options: Soldered / Hot-swap
Manufacturing: Produced in-house by OF Studio
Spec Sheet
316376-2
Price Range
$255 - 295
$255: Full Aluminum case + SS weight
$295: Aluminum top + Brass Bottom + SS weight
Internal Structure
As we all know, the inside of a keyboard is a closed or semi-closed cavity, which naturally has acoustic characteristics. With a large internal space and many parallel surfaces, it is prone to forming standing waves, leading to hollowness and echo.
To address this, we opted for a relatively straightforward solution: extending the internal structure of the bottom case to fill the space between the PCB and the case as much as possible, effectively reducing the internal cavity volume.
At the same time, sufficient room is reserved to allow for flex and downward movement of the internal assembly. Additionally, a 1.0mm Poron foam layer is added at the bottom to further improve the acoustic performance.
The top-mount plate uses a fairly standard mounting point layout.
We’ve added silicone pads between the plate and the top case to help reduce typing resonance and vibrations.
316387-3
316389-4
PCB Layout
316391-5
Content List
Keyboard case (top & bottom housing)
Plate
PCB, Type-C daughterboard, and 4-pin connecting cable
O-ring
Poron bottom foam
Screws
Rubber feet
Microfiber cloth bag
Keyboard carrying case
Inner packaging box
Outer shipping carton
Vendor List
NA: Unikeys
SEA: Ktechs
316393-6
316395-7
316397-8
316399-9
« Last Edit: Wed, 25 March 2026, 16:52:09 by DashanYYY »
Offline Frezzles
Re: [IC] OF Studio – OF1 60% Keyboard Kit
« Reply #1 on: Wed, 25 March 2026, 15:14:12 »
Looks Interesting, but is there a better view on the Sideprofile without having an angle?
« Reply #2 on: Wed, 25 March 2026, 16:44:53 »
Looks really nice
Offline Ruby437
« Reply #3 on: Wed, 25 March 2026, 17:53:10 »
So close yet so far from 6u HHKB. Looks really good otherwise!
Offline IBMweMissU
« Reply #4 on: Wed, 27 May 2026, 06:42:46 »
Is a solder PCB available too? h60 compatible? can buy without PCB?
