Author Topic: [GB]GMK CYL Thunder God - ETA Late Sept 2026  (Read 179996 times)
Offline HungHingDaiLo
  • 無間道
« on: Sat, 16 May 2026, 08:41:16 »
GMK CYL Thunder God
GB May 22 to June 15, 2026
Inspired by the Mythical Deity Raijin/Léigōng
This set features a new (doubleshot) sparkle/glitter material, particularly on the alert-style Row 1 (numrow) keys.
Base kit and Novelties kit are the only kits offered on this set.
IC Page
More info ↓
Colors
This set uses 2 custom colors and the rest are GMK stock colors, such as U9 and N9.
No 40s Support?
Alert-style R1 numrow is unusable on 40% layout.
No Sublegends?
Having six color combinations along with sublegends would make the set look overly busy, which isn't the look I'm going for.
Disclaimer
Renders may not picture actual colors of the keycaps but if you happen to have GMK stock color in your possession then the colors are the exact match of the said colors.
Production and Delivery
Production is around 4 months, after every vendors paid GMK. Expect estimate delivery around Fall/Early Winter 2026.
Base Kit - US$130
60%, Alice, up to full size layout support. F13 key, some minibars and 6u spacebar are included.
Novelties Kit - US$32
Most of the novelties are UV-print. The two (red) sparkle keycaps are doubleshot.
RENDERS
Haven TKL by Atelier Haven (PapaMaoddd)
Phidias FRL1800 by Brunosan
TGR Jane TKL by Yuktsi
SAMPLE (Red Sparkle) PHOTOS
Taken under various lighting conditions. Thanks to @edwardtanujayaa for the amazing photos!
Deskmat US$25
Thunder Goddess
900x400mmx3,5mm size, Edge-to-Print stitch, rubber bottom
Vendors
USA: Mekibo
Asia: Kbdfans
KR: Swagkeys
EU: Oblotzky
SEA: Ktechs
CA: Minokeys
OCE: Switchkeys
UK: ProtoTypist
Join HHDailo's Discord
Special Thanks
stellaidoscope for the amazing arts
Pensa for the amazing renders
Mario (GMK) for the quotation/estimate/inquiry assistances
Beetles for support
Bees.Keys for the amazing initial kit renders
and all of you
« Last Edit: Mon, 24 August 2026, 22:30:49 by HungHingDaiLo »
IG: @rayhhdailo
Re: [GB]GMK CYL Thunder God - May 22 - Jun 15 2026
« Reply #1 on: Tue, 19 May 2026, 11:45:24 »
Approved :thumb:
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #2 on: Tue, 19 May 2026, 11:46:40 »
big dog
  • 無間道
« Reply #3 on: Tue, 19 May 2026, 20:15:17 »
Added photo of keycap colors to the OP.
Purple: Custom color (Quite significantly darker than Hyperfuse's GMK DY purple)
Teal Accents: GMK TU1
Mods: GMK U9
Alphas: GMK N9
Alert Accents: Sparkle/glitter RO1
Legend color on Alert Accents is using pale yellow custom color.
IG: @rayhhdailo
Offline SwitchKeys
    • SwitchKeys
« Reply #4 on: Thu, 21 May 2026, 17:05:23 »
GL :thumb:
  • 無間道
« Reply #5 on: Fri, 22 May 2026, 06:51:03 »
Live on Most Vendors
USA: Mekibo
Asia: Kbdfans
KR: Swagkeys
EU: Oblotzky
SEA: Ktechs
CA: Minokeys
OCE: Switchkeys
UK: ProtoTypist
« Last Edit: Fri, 29 May 2026, 21:42:40 by HungHingDaiLo »
IG: @rayhhdailo
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #6 on: Fri, 29 May 2026, 20:45:04 »
Offline dvorcol
« Reply #7 on: Tue, 09 June 2026, 20:59:40 »
  <-- orders only
« Last Edit: Sun, 21 June 2026, 13:06:25 by dvorcol »
Offline dvorcol
« Reply #8 on: Sun, 21 June 2026, 13:04:10 »
Bump for final numbers. Congratulations on a successful GB!
« Last Edit: Sun, 21 June 2026, 13:06:58 by dvorcol »
  • 無間道
« Reply #9 on: Sun, 21 June 2026, 22:23:28 »
<3 dvorcol. Thank you very much!
Also all of you supporting this set.
Orders are finalized and I have approved the custom colors. Will try to post regularly for updates from manufacturing to shipping.
Can also check your local vendor you purchase the set from.
IG: @rayhhdailo
  • 無間道
Re: [GB]GMK CYL Thunder God - In Production
« Reply #10 on: Tue, 14 July 2026, 09:38:02 »
Quick update (14/7/2026):
- All custom colors have been approved
- Production renders from GMK have been approved
IG: @rayhhdailo
  • 無間道
Re: [GB]GMK CYL Thunder God - ETA Late Sept 2026
« Reply #11 on: Mon, 24 August 2026, 22:32:30 »
Update 8/25
Got news from GMK that the set will be sent to vendors in Late September 2026.
IG: @rayhhdailo
