Author Topic: How's the ZSA Moonlander?  (Read 12930 times)
Offline Happyduck
  • Long-time lurker, finally decided to make an acc
« on: Sun, 31 May 2026, 11:26:11 »
I'm debating to get hold of the ZSA Moonlander. Anyone on here that tried it out? How's your overall experience with it?
« Last Edit: Sun, 31 May 2026, 11:45:32 by Happyduck »
Offline zegonix
Re: How's the ZSA Moonlander?
« Reply #1 on: Mon, 15 June 2026, 03:08:00 »
i never owned, or actually used one myself. but many colleagues at work have one.
from what i can tell:
+ good layout for many
- very expensive
- proprietary software
- insane construction for the stabilizers on the big thumb buttons
if you do not have the requirement of being able to maintain your keymap as text file and flash firmware from a terminal and just want something that works, it might be a good buy.
but as i said: take everything i wrote with a good amount of salt.
« Last Edit: Wed, 24 June 2026, 07:56:22 by zegonix »
Offline PandaKB
  • Ergo Evangelist. Your wrists can thank me
    • PandaKB
« Reply #2 on: Wed, 08 July 2026, 21:48:29 »
The casing near the thumb zone hinge split open, but the keyboard works totally fine.
Offline Quirus
« Reply #3 on: Thu, 17 September 2026, 05:45:41 »
Interesting insights, thanks! How hard is the learning curve for this split layout? How long did it take for your colleagues to get back to their normal typing speed? Given the high price, I wouldn't want to buy it just to end up leaving it on a shelf.
