Author Topic: [IC] Keykobo X Pixtendo Lab - Pixel 67 Keyboard  (Read 21270 times)
Offline DashanYYY
    • Unikeys
« on: Tue, 02 June 2026, 13:49:24 »
Keykobo: https://discord.gg/YDHeEw6W69
317267-0
Unikeys: https://discord.gg/sFAezFTBpp
317307-1
PIXEL 67
Based on the stream feedback, we have made the following updates for the GB version:
1. Fully built kits will include extra ISO keys, split backspace keys, and Mac system keys, 7U spacebar keycap etc.
2. The front case text will be simplified. We will remove the more complex decorative text and keep only the "Pixel67" name at the top-left corner. Everything else will be removed.
3. The stabilizers will be further tuned to reduce unwanted noise.
4. The machining tolerance between the top and bottom case will be improved for a tighter and more precise fit. Keykobo used a standardized case dimension and tolerance across all units to reduce production costs. However, during manufacturing, the case dimensions and tolerances should have been adjusted based on the surface treatment being applied.
The anodized and spray-coated versions require different tolerances because the spray-coated finish adds a thicker layer to the surface. As a result, using the same tolerance specification for both finishes can lead to fitment issues on the spray-coated units.
Where the inspiration comes from
Hello everyone,
I am a custom keyboard enthusiast from Japan, currently living in Silicon Valley, and I have been part of this hobby for about 8 years.
Pixel67 began with my love for old IBM and Apple keyboards. I have always been drawn to the way those early keyboards created such a strong visual identity through simple lines, limited colors, and bold proportions. They were not trying to look luxurious, yet they carried a kind of honest, functional beauty that still feels memorable today.
With Pixel67, I wanted to create a retro-inspired 67% custom keyboard that feels nostalgic without feeling outdated, solid without becoming unnecessarily heavy or complicated, and personal without losing everyday usability.
With the help of my friends at Keykobo, we spent the past 8 months developing the design, structure, colorways, and prototypes. From the case proportions to the internal brass weight, tri-mode PCB, and redesigned gasket structure, the goal was to create a complete custom keyboard experience while keeping the project approachable.
Design Details
Pogo Pin Gasket Mount
317269-2
The Pogo Pin Gasket Mount was by far the most time-consuming part of the Pixel67 to develop and fine tune. We went through extensive testing to achieve a typing experience that feels balanced, controlled, and consistently comfortable.
Compared to traditional PCB leaf spring or plate leaf spring gasket designs, the pogo pin structure provides much better consistency in typing feel across the board. Each pogo pin requires nearly identical force to compress, which creates a more even and predictable rebound throughout the keyboard. This helps eliminate uneven support between different areas of the plate and PCB.
Another major advantage is long-term durability. Traditional gasket or leaf spring structures can gradually fatigue over time, but pogo pins maintain their characteristics without losing responsiveness or support. This allows the keyboard to preserve its original typing feel even after extended use.
The final result is a keyboard with a controlled amount of flex that feels comfortable without becoming overly soft or unstable. The pogo pins provide enough support to the PCB and plate assembly to create a clean, stable, and very pleasant typing experience while still retaining the elasticity in a gasket mount design.
Internal Brass Weight
317271-3
The internal brass weight adds substantial heft to the keyboard, giving the Pixel67 a more premium and grounded feel on the desk. Beyond the added weight, the high-density brass also plays a major role in shaping the keyboard’s acoustic profile.
The brass weight helps dampen unwanted resonance inside the case while filling out the internal structure to reduce empty space. This results in a cleaner and denser sound signature with significantly less hollow or pinging noise, even in a foamless configuration.
Combined with the overall mounting design, the internal brass weight helps create a typing experience that feels solid, controlled, and acoustically refined without sacrificing comfort or flexibility.
317272-4
Keycaps and Switches
317291-5
Pixel67 is available in both Pre-built and bare-bone configurations to accommodate different preferences within the keyboard community.
The Pre-built version comes fully assembled and ready to use out of the box. It includes:
1. Keykobo ABS Doubleshot Keycap Set (MAC keys will be included in the keyboard kit)
2. HMX Clacky Switches (PC Top Housing, LY Stem, P2 Bottom Housing)
3. Tuned and lubed stabilizers
4. Foam Kit
For enthusiasts who prefer building and customizing their own setup, the Barebone version comes without switches, stabilizers and keycaps, allowing users to freely choose their preferred parts.
Keyboard Specs
Pixel67 was designed from the ground up with long-term typing comfort in mind.
The front lip of the keyboard features a subtle slope that naturally fits the angle of your hands and wrists, allowing for a more comfortable typing posture without requiring a wrist rest. This creates a smoother transition from desk to keyboard and helps reduce fatigue during extended typing sessions.
The keyboard also utilizes a balanced 6-degree typing angle, which is widely considered one of the most comfortable and natural angles for everyday typing. It provides an ergonomic typing position suitable for most users without feeling too flat or overly aggressive.
For customization enthusiasts, Pixel67 fully supports both VIA and QMK. Users can freely remap keys, create custom layers, configure macros, and personalize the keyboard layout entirely to their own workflow and preferences.
317296-6
317298-7
317300-8
317302-9
317304-10
Color Options
317309-11
Four colors are available: System Silver, Classic Beige, Terminal Green, and Vintage Brown. A matching ABS double-shot keycap set will be provided if the pre-built option is selected at checkout.
Price Range
Please note that this is an estimated price. The final pricing will be announced before GB starts.
Pre-built Pixel 67: Estimated $189 USD
Barebone Pixel 67: Estimated $149 USD
Vendors
Global: Unikeys and Keykobo
US:
EU:
AU:
SEA:
KR:
We hope you like the project, and I would truly appreciate your feedback.
« Last Edit: Mon, 15 June 2026, 13:20:07 by DashanYYY »
Re: [IC] Keykobo X Pixtendo Lab - Pixel 67 Keyboard
« Reply #1 on: Tue, 02 June 2026, 14:11:15 »
Love me some big bezels
Offline theloosegoose18
« Reply #2 on: Tue, 02 June 2026, 16:49:40 »
Ohhh, this is such a sweet project. For sure copping one of these!
Offline DirtyGingy
« Reply #3 on: Tue, 02 June 2026, 17:20:41 »
This board doesn't look bad, but I wanted to share something that the community learned several years ago.
Side gaskets are generally bad. They make the assembly feel a bit stiff and choke/dampen the sound way too much. It leads to an uneven typing feel and uneven sound.
That said, you can just not install them as the end user from what I can see of your renders.
Offline DirtyGingy
« Reply #4 on: Tue, 02 June 2026, 17:23:25 »
Also, Are there any other plates for this board? I'm not seeing variations in layout options either.
Offline tunb
« Reply #5 on: Tue, 02 June 2026, 22:10:18 »
how many mode connect ?
Offline DashanYYY
    • Unikeys
« Reply #6 on: Tue, 02 June 2026, 23:16:00 »
Thank you very much for the feedback. And yes there will be other plate options available.
Offline DashanYYY
    • Unikeys
« Reply #7 on: Tue, 02 June 2026, 23:16:48 »
Offline DashanYYY
    • Unikeys
« Reply #8 on: Tue, 02 June 2026, 23:17:11 »
Trimode will be available
Offline WholesomeDucky
  • lemme get uhhhhhhhhhhhhh bread
« Reply #9 on: Tue, 02 June 2026, 23:43:28 »
Kinda like this, especially at that price, but I can't get over the distracting stuff on the top. Personally I'd remove all the text on the top and keep the accent in the bottom right corner.
12 years of spending money on typing
"Name checks out" -Kustoms, 2020
Discord:wholesomeducky
Inbox always open, for whatever reason.
Offline decta
« Reply #10 on: Mon, 08 June 2026, 06:56:24 »
these are awesome but as already mentioned it would be great if the text could be left off. would be 5$ more to not have text on it. and it might save 5$ on production.
Also, any plans to release a TKL in that style?
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #11 on: Thu, 11 June 2026, 05:44:41 »
The side gaskets did me a lil concern, but overall this keeb is cute! I'm very interested!
Current Boards: Aaru TKL (Old Dark Sand) | Drop + Planck (Purple) | Mr Suit WKL (Black w/Gold Chamfers) | Sangeo60 (Black) | KBD67Lite (White) | D45 (E-Grey) | Wind X (Pink) | NCR 80 (Beige) | QK65 (Dark Green) |Av4 Claymore | TGR x Monokei Tomo (Suave Blue) | Heracles80 (Holy White) | Snake60 (Rust) | Array (E-White) | Capsule (E-White) | QK75 (E-White) | | QK80 (Black) | Envoy 65 (Clear PC) | Mode Sonnet (Ice Blue) | Cycle 7 (Lavender, E-White) | Neo70 (Retro White, Black) | Reflection (Chocolate) | Matra Alice 90 (Glossy Red) | Haven TKL (Silver/Red) | Baldur64 (Black) | XOX70 (Bonsai) | SWISS | Cycle 80 (Zeal)| QK80 MKII (Pink) | Polygon 7 (Grey) | QK75N (Smile Yellow) | Han80 (Beige) | THE BASE (Black) | NV-70 (Silver) | Matrix Carnival (Asagao Purple)
Offline matthewgreenberg
« Reply #12 on: Thu, 11 June 2026, 17:35:45 »
Hi! Came here from Alexotos' stream, extremely interested in the keyboard!
I also am hoping it's possible to get a version of the keyboard without the text! The text on the USB port side of the keyboard and bottom aren't a huge deal to me, but I find the text on the top to be a big negative. If it was up to me I'd remove all of it and just leave the little accent light, but the "Keys Were Enough" text on the wrist rest area is definitely the most distracting. The design is beautiful and would be so clean without the text. I love big bezel keyboards and this is extremely up my alley!
Crossing my fingers, it's a definite buy for me if there's a no text option! Extremely interested to try the soft typing feel Alex showcased.
« Last Edit: Thu, 11 June 2026, 17:43:38 by matthewgreenberg »
Offline DashanYYY
    • Unikeys
« Reply #13 on: Mon, 15 June 2026, 12:40:28 »
Thank you very much for the feedback! We have communicated with keykobo and Pixtendo, and for the official pre-order run, we are going to remove most of the text on the front except for the "Pixel 67" branding on the top left. The front design will be much more clean this way.
Offline SammyJim
« Reply #14 on: Tue, 16 June 2026, 07:43:37 »
Very excited for this! Is the little light on the top case just a power light, or does it have any function such as changing color as a caps lock indicator?
