Author Topic: [IC] DBD x GSD CCRE TKL  (Read 21212 times)
Offline godsson
« on: Sat, 13 June 2026, 18:59:33 »
CCRE TKL
Excited to launch the IC for the CCRE TKL I've been working on for the past 6 or so months. After a couple of rounds of prototypes and revisions, I'm finally happy with the design and sound.
The CCRE TKL is based on DesignedByDark's CCRX open-source design, which uses a modified Ex: Ecliptica spring leaf top-mount plate. My rendition brings sharpened styling, a large through weight with acoustic perforations, internal acoustic grooves, universal right-side USB PCB support, and gummy o-ring mount to the keyboard. A full list of changes is available in the project channel in my server (linked below).
This was created with Dark's blessing. Huge shoutout to him for all of his awesome contributions to the hobby over the years.
Details
  • Layout: TKL
  • Mounting style: Leaf-spring top, gummy o-ring (clip-in stabs only)
  • Front height: 16.5mm -> 12.5mm (cherry lip)
  • Typing angle: 7 degrees
  • Weight: 2.95kg (unbuilt)
  • PCB Compatibility: Universal onboard right side USB (north-facing spacebar for o-ring)
Kit Contents
  • Anodized 6063 aluminum top case
  • Anodized 6063 aluminum bottom case
  • Anodized 5052 aluminum plate
  • Sandblasted & clear coated brass through weight
  • CC H87 / H88 TKL Solder PCB
  • Cleaning cloth
  • Custom GSD carrying case
  • 50a gummy o-ring
Renders
Typing Tests & Build VODs
Rukia's Build VOD
Vendors
  • TBD depending on interest
Links
Form
Discord
Instagram
YouTube Typing Tests
YouTube Stream VODs
Twitch
« Last Edit: Thu, 18 June 2026, 13:40:04 by godsson »
Offline godsson
Re: [IC] DBD x GSD CCRE TKL
« Reply #1 on: Mon, 15 June 2026, 15:41:16 »
Reserved.
Offline goodnaruk
« Reply #2 on: Thu, 18 June 2026, 13:45:37 »
instant classic.
Offline NightFox99
« Reply #3 on: Thu, 18 June 2026, 13:46:59 »
Yes, please
Offline Foxicious
« Reply #4 on: Thu, 18 June 2026, 13:49:02 »
I'm in, waiting to see the finalization and EU price. Really what you've done with this one
Offline flittyregg
« Reply #5 on: Fri, 19 June 2026, 23:43:22 »
Looks great  :cool:
