Author Topic: [GB] Keykobo X Pixtendo Lab - Pixel 67 Keyboard  (Read 34166 times)
Offline DashanYYY
    • Unikeys
« on: Mon, 15 June 2026, 12:56:14 »
317460-0
Unikeys: https://discord.gg/sFAezFTBpp
Keykobo: https://discord.gg/YDHeEw6W69
Pixel 67 Keyboard Kit
Sales Link: https://unikeyboards.com/products/pixtendo-pixel-67-wireless-keyboard-pre-order
317462-1
Hello everyone,
Thank you for all the feedback during the Pixel67 IC. After reviewing the comments and making final adjustments, Pixel67 is now ready for Group Buy.
Based on the stream feedback, we have made the following updates for the GB version:
1. Fully built kits will include extra ISO keys, split backspace keys, and Mac system keys, 7U spacebar keycap etc.
2. The front case text will be simplified. We will remove the more complex decorative text and keep only the "Pixel67" name at the top-left corner. Everything else will be removed.
3. The stabilizers will be further tuned to reduce unwanted noise.
4. The machining tolerance between the top and bottom case will be improved for a tighter and more precise fit. Keykobo used a standardized case dimension and tolerance across all units to reduce production costs. However, during manufacturing, the case dimensions and tolerances should have been adjusted based on the surface treatment being applied.
The anodized and spray-coated versions require different tolerances because the spray-coated finish adds a thicker layer to the surface. As a result, using the same tolerance specification for both finishes can lead to fitment issues on the spray-coated units.
Pixel67 is a retro-inspired 67% custom keyboard designed around simple lines, classic colorways, a Pogo Pin gasket mount, tri-mode connectivity, and an internal brass weight.
317472-2
Colorways
Classic Beige — timeless beige inspired by early personal computers.
317464-3
Vintage Brown — warm retro tones inspired by old electronic equipment.
317466-4
Terminal Green — deep green inspired by classic computer terminals.
317468-5
System Silver — clean silver with a more modern technical feel.
 317470-6
Design and Specs
Pogo Pin Gasket Mount
The Pogo Pin Gasket Mount was by far the most time-consuming part of the Pixel67 to develop and fine tune. We went through extensive testing to achieve a typing experience that feels balanced, controlled, and consistently comfortable.
Compared to traditional PCB leaf spring or plate leaf spring gasket designs, the pogo pin structure provides much better consistency in typing feel across the board. Each pogo pin requires nearly identical force to compress, which creates a more even and predictable rebound throughout the keyboard. This helps eliminate uneven support between different areas of the plate and PCB.
Another major advantage is long-term durability. Traditional gasket or leaf spring structures can gradually fatigue over time, but pogo pins maintain their characteristics without losing responsiveness or support. This allows the keyboard to preserve its original typing feel even after extended use.
The final result is a keyboard with a controlled amount of flex that feels comfortable without becoming overly soft or unstable. The pogo pins provide enough support to the PCB and plate assembly to create a clean, stable, and very pleasant typing experience while still retaining the elasticity in a gasket mount design.
317474-7
Internal Brass Weight
The internal brass weight adds substantial heft to the keyboard, giving the Pixel67 a more premium and grounded feel on the desk. Beyond the added weight, the high-density brass also plays a major role in shaping the keyboard’s acoustic profile.
The brass weight helps dampen unwanted resonance inside the case while filling out the internal structure to reduce empty space. This results in a cleaner and denser sound signature with significantly less hollow or pinging noise, even in a foamless configuration.
Combined with the overall mounting design, the internal brass weight helps create a typing experience that feels solid, controlled, and acoustically refined without sacrificing comfort or flexibility.
317476-8
Front and Rear
317478-9
317480-10
VIA and QMK Compatible
317482-11
PRE-BUILT KIT BONUS
The Pre-built version comes fully assembled and ready to use out of the box. It includes:
1. Keykobo ABS Doubleshot Keycap Set (extra ISO keys, split backspace keys, and Mac system keys, 7U spacebar keycap etc)
317484-12
2. HMX Switches: There are 3 options available.
Pix Cloud: A light spring weight clacky switch
Pix Stone: A heavy spring weight clacky switch
Pix Moss: A thocky Light Tactile switch
317486-13
3. Tuned and lubed stabilizers
4. Foam Kit
For enthusiasts who prefer building and customizing their own setup, the Barebone version comes without switches, stabilizers and keycaps, allowing users to freely choose their preferred parts.
Design Concept
Pixel67 started from our love for early IBM and Apple keyboards. We have always been fascinated by the way those early keyboards used simple lines, limited colors, and strong proportions to create a memorable visual identity.
With Pixel67, we wanted to create a retro-inspired 67% keyboard that feels nostalgic but not outdated, solid but not unnecessarily expensive, and personal without being overly complicated.
Specifications
Layout: 67
Mounting:Pogo Pin gasket Mount
Plate Options: PP, FR4, and aluminum.
Case Material: Aluminum
Weight Material: Internal brass weight
Weight: Approx. 2.87kg built with switches and keycaps
Typing Angle: 6°
Front Height: 15.7mm
Rear Height: 34.8mm
PCB:Tri-mode hot-swap PCB
PCB: 1.6mm thick PCB.
Connectivity: USB-C / Bluetooth / 2.4GHz
Firmware:QMK / VIA support
Barebone Kit Includes
•   Aluminum top case
•   Aluminum bottom case
•   Tri-mode hot-swap PCB
•   Plate
•   Internal brass weight
•   Pogo Pin gasket components
•   Foam kit
•   Silicone feet
•   Screws and accessories
•   Keyboard Case
•   User Manual
Keycaps and switches are not included in the base kit unless otherwise specified.
Pre-Built Kit Includes
•   Pixel67 keyboard kit
•   Switches
•   Keycaps
•   Stabilizers
•   Extra ISO keys
•   Split backspace keys
•   Mac system keys
•   Foam kit
•   Keyboard Case
•   User Manual
For fully built kits, the foam kit will be included separately in the accessory package instead of being pre-installed. Buyers can choose whether to install it according to their own preference.
Group Buy Information
Group Buy Start: June 16th, 2026
Group Buy End: July 16th, 2026
Estimated Fulfillment: October 15th, 2026
Base Kit Price:149USD
Fully Built Kit Price:189USD
Vendor
World Wide & CA: Unikeys https://unikeyboards.com/products/pixtendo-pixel-67-wireless-keyboard-pre-order
US: Divinikey
DE: MonacoKeys
Australia: KeebzNcables
UK: Prototypist
Singapore: KTechs
Vietnam: MOKB
China:Keykobo
Content
Alexotos:
t=1975s
Scooped Bar:
Captain Sterling:
Keebtaro:
The timeline may be adjusted depending on production and QC progress. We will provide updates throughout the process.
Thank you again for the feedback during the IC stage.
Pixel67 has been built around retro design, practical structure, and an accessible price point. We are excited to bring it to GB and look forward to hearing your thoughts.
[/size]
[/color]
« Last Edit: Tue, 16 June 2026, 15:53:47 by DashanYYY »
Offline clarenceawad
Re: [GB] Keykobo X Pixtendo Lab - Pixel 67 Keyboard
« Reply #1 on: Wed, 17 June 2026, 02:26:27 »
Vendor
World Wide & CA: Unikeys https://unikeyboards.com/products/pixtendo-pixel-67-wireless-keyboard-pre-order fnaf
US: Divinikey
DE: MonacoKeys
UK: Prototypist
Singapore: KTechs
Vietnam: MOKB
China:Keykobo
First! This looks impressive, can’t wait! :thumb:
« Last Edit: Mon, 02 November 2026, 01:47:26 by clarenceawad »
