Author Topic: [GB] Wired In Sonoma - Alu + Steel/Copper 65% | 4 Colorways | LIVE til Jul 31  (Read 85220 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
SONOMA
FORM, FROM THE MOON.
by Wired In and Beni Klein
An aluminum 65% named for the valley of the moon.
Three ways to mount. Two durometers. Four moon-phase colorways.
» RESERVE YOURS «
Explore the full landing page →
THE GROUP BUY IS LIVE
The Sonoma group buy is open now and runs June 20 → July 31, 2026, with fulfillment targeted for Q1 2027. Every board is made to order during the buy — lock in the colorway, PCB, and plate you want before the window closes.
» Reserve directly: wiredinstore.com/products/sonoma
» Full landing page (renders, motion, spec sheet): landing.wiredinstore.com/sonoma
WHAT IS SONOMA
Sonoma is a Winkey 65% by Wired In and Beni Klein, built around a single idea: a circle inside a rectangle. Named for the valley of the moon, the whole board leans into that — soft geometry, a magnetic accent that phases like a moon, and four colorways drawn from the lunar cycle.
Underneath the concept, it's a serious enthusiast board. A full aluminum chassis (frosted polycarbonate on Flux), a swappable magnetic accent, and a mounting system that tunes the typing feel three different ways across two gasket durometers. Solder or hotswap. Aluminum, carbon fiber, or FR4 plate. You build the feel you want.
FOUR FINISHES — THE PHASES
Four colorways, each a phase of the moon. The magnetic accent and weight are finished to match.
  • STERLING — silver anodized aluminum with clear-coat stainless steel accents and weight.
  • BLOOD MOON — red anodization over polished black PVD stainless steel accents and weight.
  • LUNAR — cream e-coat over clear-coated copper accents and weight.
  • FLUX — frosted polycarbonate with clear-coated copper accents and weight.
THREE WAYS TO MOUNT
Sonoma ships with the hardware to run any of three mounts, so you can dial the feel from isolated-and-soft to maximum flex without buying anything extra.
  • O-ring mount — isolated and soft.
  • Gasket-mounted plate assembly — balanced.
  • Bare PCB on gaskets — maximum flex.
Two durometers, both in the box:
  • 50A (orange) — soft cushion.
  • 80A (black) — firm, direct.
See the mounting swap and flex in motion on the landing page.
MAGNETIC. INTERCHANGEABLE.
The rear accent piece is held by magnets — no tools, no screws. It's the "moon" of the board, and it lifts straight out so the finish can phase with your build. Colorway-matched accent and weight on every unit.
SPECIFICATIONS
  • Layout: Winkey 65% (standard)
  • Case: anodized aluminum (frosted polycarbonate on Flux)
  • Typing angle: 6.85°
  • Width: 339.61 mm
  • Depth: 115.62 mm
  • Total height: 34.21 mm
  • Front height: 20.89 mm
  • Mounting: O-ring / gasket plate / bare-PCB gasket (all three included)
  • Gaskets: 50A + 80A durometers included
  • PCB: Solder or Hotswap
  • Plate: Aluminum, Carbon Fiber, or FR4
  • Accent + weight: magnetic, interchangeable, colorway-matched
IN THE BOX
  • Case (top + bottom)
  • Plate (your chosen material)
  • PCB (solder or hotswap)
  • Magnetic accent piece + weight (colorway-matched)
  • All three mounting solutions — O-ring + gasket hardware
  • Both gasket durometers — 50A (orange) + 80A (black)
  • All necessary screws + carry case
Kit only — switches, keycaps, and stabilizers are not included.
PRICING
  • From $349 USD — Solder PCB, any colorway, choice of Aluminum / Carbon Fiber / FR4 plate
  • +$5 (=$354) — Hotswap PCB
  • Extras — spare plates, PCBs, and gasket sets available as add-ons at checkout
Pricing is identical across all four colorways. Reserve at wiredinstore.com/products/sonoma.
WHERE TO BUY — REGIONAL VENDORS
Buy directly from Wired In (US / international), or through a regional vendor to save on shipping and duties:
REVIEWS & CONTENT — INCOMING
The promotional units came out absolutely gorgeous — and they're on their way to content creators right now for review and content. Captain Sterling, Jeoff, and Keyboard Dad are among the first to receive theirs. We'll update this thread with review and video dates as soon as they're locked in, so keep an eye here and on the landing page.
TIMELINE
  • 01 · Group Buy — LIVE (June 20 → July 31, 2026)
  • 02 · Group buy closes / invoicing
  • 03 · Production kickoff
  • 04 · Manufacturing
  • 05 · QC
  • 06 · Shipping to Wired In + vendors
  • 07 · Fulfillment — targeted Q1 2027
Live progress is tracked on the landing page and our public Build Log.
LINKS
Renderings represent the final product. Pre-sale orders are non-refundable and cannot be cancelled once the group buy closes. Discount codes are not permitted; if used, the remaining balance will be invoiced before fulfillment. Items ordered alongside the pre-order ship together at the time of the latest available item — contact us if you need the order split and we'll invoice the difference in shipping. International customers: please ensure your name and shipping address are in English. Fulfillment timelines are targets and may shift with manufacturing.
Approved :thumb:
