Author Topic: [IC] Code:002 TKL Keyboard  (Read 105348 times)
Offline Sinner
  • MX Purple enjoyer
« on: Tue, 07 July 2026, 23:08:47 »
Code:002 TKL
317666-0
Hello everybody, Sinner here. Finally making the step to posting an IC on GeekHack.
Code:002TKL has been a project that I've been working on together with a friend Raimi for a good year and we are finally ready to share it out with you guys. After two prototypes we are happy with the design and we want others to be able to enjoy it as well.
Price is dependant on the MOQ hit, and is subject to change. Expected range of 550-725 USD (25-50 MOQ).
IC will be open for 1 month to gauge the numbers and interest. Group buy is expected to open in September 2026.
Currently one vendor: Cafege. Please leave a comment if you would like to see other vendors considered. Vendors are welcome to contact me as well regarding vendoring the board.
Google forms: https://forms.gle/LLAwz2ee2tx2Tr5bA
Discord : https://discord.gg/M34xhUzVbV
Specifications
- Mounting: Top Mount/O-ring mount
- Case Material: 6063 Aluminum
- Outer Weight Material: Polished Stainless Steel
- Inner Weight Material: Brass
- Plate: 5052 Aluminum
- Badge: Polished Stainless Steel
- Horns: 6063 Aluminium
- Typing Angle: 9 Degrees
- Front Height: 16.5 mm
- PCB: 1.6mm CEM3 (Cafege TKL PCB)
- Colours: Top Pantone 7422C, Bottom RAL3003 Horns RAL3003 and plate RAL3003 (colour matched to GMK Darling R1)
Kit inclusions
-Keyboard case WKL ONLY
-Aluminium Plate
-CEM3 Solder PCB (Cafege TKL PCB) designed by Harky
-Universal Daughterboard + JST Cable
-Screws
-Bump-on feet
-Viton Oring (same as the one sold by cafege)
-Horns
-Badge
1st prototype
317668-1
317670-2
317672-3
 2nd prototype
317674-4
Build stream by Benji of the 2nd prototype -
Thank you for reading, for further questions or information join the discord server or leave a comment.
« Last Edit: Wed, 08 July 2026, 01:11:17 by Sinner »
Offline lucastr
Re: [IC] Code:002 TKL Keyboard
« Reply #1 on: Sun, 12 July 2026, 22:33:49 »
 :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p
Offline k4x1
« Reply #2 on: Sun, 12 July 2026, 22:34:32 »
Absolutely fkn radical  :eek:
Offline Gemmmmmmmmmmmmmy
« Reply #3 on: Sun, 12 July 2026, 22:55:35 »
GLWIC vro  :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p :p
Life seems so much smaller
Swim to the moon
Offline Fede_Feo
« Reply #4 on: Sun, 12 July 2026, 23:26:13 »
Getting horny for this one!
Offline Bume1945
« Reply #5 on: Sun, 12 July 2026, 23:50:44 »
The proportions on this are fantastic. GLWIC!
Offline Fede_Feo
« Reply #6 on: Mon, 07 September 2026, 08:38:54 »
BUMP
Offline Nevrest
« Reply #7 on: Fri, 11 September 2026, 15:18:05 »
That mirror finish PVD   :cool:
Offline Kool-Keys
    • Kool Keys
« Reply #8 on: Sat, 19 September 2026, 00:39:00 »
Bump
Need.
