MW Meteor Dreams
LINKS
INSPIRATION
Far above a distant skyline veiled in drifting haze, a beam of luminous green cuts across the heavens.
A falling star, burning in its final stand against fate, blazes with quiet ferocity against the dying of its light.
In its glowing wake remain the echoes of a grand journey: friendships forged through adversity, rivalries that shape destiny, and the quiet determination to keep moving forward when the path ahead is uncertain.
Meteor Dreams is inspired by a world that blends fantasy and science fiction, a saga that has captured the imagination and hearts of many. It is an invitation to remember adventures with cherished companions across distant lands, and dreams that refuse to fade.
So even when the clouds gather: Charge forward. Break limits. Defy destiny.
After all, sometimes the brightest light in the sky is the one we choose to follow.
KITS
Base
Novelty
Trail
[Alternate looks. i.e. double stripe, normal F-row legends. Keyboards without an F-row can also substitute the R1 num-row with these accent keycaps too for the roman numeral aesthetic]
Materia
Numpad
Spacebar
Forties
NorDeUK
GALLERY
Katana 80
Katana 65XT
SharkFRL & MK65-XT
Disclaimer: Renders shown may not perfectly display the actual colors and/or texture of the keycaps. Please refer to actual photo samples to see the real colours and texture. These are best attempts at emulating the semi-translucent nature of the keycaps, whilst noting that lighting conditions and screen calibrations are also variables that affect colour representation/perception.
SPECIFICATIONS
Manufacturer: Milkyway Keys
Profile: Cylindrical Cherry
Sculpt: 1-1-2-3-4-4
Material: ABS Plastic
Legends: Double-shot injection
Compatibility: Mx-style switches
SAMPLE
Sample of primary gradient legends on white. Middle strip is with white backlighting
Accent samples
Materia kit samples
Designer Comments:
The coloured legends are semi-translucent, with unique flow marks. These textures are formed as the molten plastic cools inside the mold and can appear as faint swirls, or inconsistent changes in sheen. This is an intended effect, with similar characteristics seen in my prior keycap set design MW Jade Dragon. Heres a photo album with some close-up photos of the effect.
I also wanted to design a keycap set that would look nice in the dark too, thus the semi-translucent material of the legends on the white keycaps allows for some shine-through. A backlit keyboard would actually evoke the otherworldly glow of the blue-green gradient and materia colours best. Do note that this shine-through effect is primarily limited to the non-accented keycaps.
DESKMATS
Meteor Wake
Dreamfall
Flow: Aether
Flow: Mako
VENDORS
Group-buy Date: 1st June 2026 to 30th June 5th July 2026
Estimated Production completion: ~2-3 months following GB date
MISC
Interest Check thread: [IC] MW Meteor Dreams
ACKNOWLEDGMENTS
Thank you goes out to:
pattycannotdesign, whose project
KAP Buff Bride (which is currently in-stock), inspired my approach. Thanks for blessing me with use of your meteor icon and other novelty ideas. Thanks for the lovely feedback and support <3
> Fellow enthusiasts who supported my prior projects: KKB Kintsugi Shiro, KKB Nichirin, GMK Black & Gold, PBTFans Atomic Purple, KAT Space Dust, KAT Great Wave, MW Jade Dragon, Clackitty Catpads, Cherry Blossomx
> The manufacturer MWKeys for trusting my vision, experiments with samples, and their patience/willingness on getting this project to GB
> □²
> Pensa 4 the 3D
> Designers of the respective keyboards depicted (myself w zlobin's assistance)
> AiglatsonStudio for inspo on the folded style deskmat
> Nopunin10did and Konstantin for being the original kitting wizards whose advice on previous projects of mine (and others) have led to my foundational knowledge and decision making (any mistakes or peculiarities are mine)
