Author Topic: Why TKL Keyboards Have an F13 Key  (Read 2653 times)
Offline Ruseupi
    • https://brunch.co.kr/@ruseupi
« on: Sun, 16 August 2026, 23:39:01 »
Heads up, this is only the second time I've written a post in English, so apologies in advance for any awkward phrasing. (*한국어 원문: https://brunch.co.kr/@ruseupi/251)
The first CNC-machined aluminum TKL cases were built by cannibalizing Cherry MX3000 boards for parts.
Back then, custom controllers (like LIMKB or Aikion, Korean DIY controller projects) didn't exist yet, so the group-buy PCB and case relied entirely on donor parts from the MX3000, including its controller, switches, keycaps, and even stabilizers.
The black 3000 shown uses thick POM keycaps, while the light gray one uses thin PBT keycaps. However, the black MX3000 used to be sold with a Winkey layout and double-shot keycaps.
At the time, TKL layouts needed a separate key just to control Num Lock. Originally that spot held a Num Lock keycap, but today's boards usually place an F13 keycap there instead.
For reference, the Cherry MX1800 layout has an LED indicator to the right of F12. This is likely why the modern F13 position ended up there.
Of course, older keyboards had function keys all the way up to F24, but this post is specifically about why F13 shows up on TKL keyboards, so hope that clears up any confusion.
I originally posted this on r/MechanicalKeyboards, but wanted to share it here on Geekhack as well since I know a lot of you appreciate the history side of things.
« Last Edit: Wed, 19 August 2026, 11:50:00 by Ruseupi »
Re: Why TKL Keyboards Have an F13 Key
« Reply #1 on: Mon, 17 August 2026, 07:12:12 »
These days, I think however the most common reasons are:
- Aesthetics, to keep all spacing between key groups 0.25u
- Space for rotary encoder knob
- Because Macintosh has F1–F12 and then an additional key, traditionally for Eject but more lately Lock Screen / Touch ID and many mainstream keyboard brands follow.
« Last Edit: Mon, 17 August 2026, 09:05:01 by Findecanor »
Offline Ruseupi
« Reply #2 on: Mon, 17 August 2026, 16:03:09 »
I think so too. But my post was specifically about the position of the F13 key on tenkeyless keyboards, why it ended up there in the first place.
To explain that, I had to bring up the first group-buy tenkeyless aluminum keyboards around 2006-2007, which came from someone who was originally producing plates for the MX1800 and MX3000.
These days a lot of people just assume F13 is there as a spot for artisan keycaps, so I wanted to trace it back to where it actually started.
« Last Edit: Mon, 17 August 2026, 17:02:22 by Ruseupi »
