Author Topic: TI-99/4A keycaps - Cherry compatible??  (Read 4364 times)
Offline mr_a500
« on: Fri, 12 November 2010, 15:26:57 »
I've always loved the crisp, thick plastic, double-shot keycaps on the TI-99/4A - and for a while, I've had a vague idea that maybe I could find a way to use them on a modern keyboard. Well, I popped a couple off today and look what I found:
I'm not absolutely certain, but doesn't that look Cherry compatible? I don't have a Cherry keyboard, so I can't test it. If it is, then I think I'll start loading up on dead TI-99 computers.
Of course, the TI-99/4a doesn't have all the keys needed for a modern keyboard, but the keys that are replaced will look great.
Offline Fwiffo
« Reply #1 on: Fri, 12 November 2010, 15:38:35 »
Nothing a Dremel or something couldn't fix (assuming the stem fits also).
You can call me... Keyboard Otaku... or not quite...
Offline didjamatic
« Reply #2 on: Fri, 12 November 2010, 15:38:49 »
If you're into keyboards enough to pop caps, you need a cherry keyboard.
(Oh, See my avatar :)
Offline mr_a500
« Reply #3 on: Fri, 12 November 2010, 15:39:05 »
OK, I've just been looking at some Cherry switches and I see the problem.
Offline mr_a500
« Reply #4 on: Fri, 12 November 2010, 15:45:29 »
I also opened my 1980 TRS-80 Model III today and look what I found:
Hmm....
Offline Soarer
« Reply #5 on: Fri, 12 November 2010, 16:05:26 »
Quote from: ripster;246074
topological puzzles....
Erm... they are topologically equivalent to Cherry keycaps ;-)
Offline lowpoly
« Reply #6 on: Fri, 12 November 2010, 16:22:47 »
Looks like these Alps switches are similar to those in the Apple M0110. All the time I could have just got a TI99/4A for more switches, lol.
Took one of my M0110 caps and put it on a Cherry stabilizer. No tight fit (wiggle, wiggle).
Edit: It was the stabilizer that wiggled. Tried it on a blue stem and it fits. Not very tight but fits. The puzzle still applies though.
« Last Edit: Fri, 12 November 2010, 16:30:47 by lowpoly »
Offline mr_a500
« Reply #7 on: Fri, 12 November 2010, 16:53:13 »
The Kaypro keys look even more compatible. (not sure about the angled keytops though)
Notice how much thicker the blue keys are.
Offline rantenki
    • http://armyofevilrobots.com/
« Reply #8 on: Fri, 12 November 2010, 23:21:02 »
Spoiler alert!
.hctiws eht fo pot eht tih dluow tI .gnicarbssorc eht si tI
Offline hfcobra
« Reply #9 on: Fri, 12 November 2010, 23:28:36 »
they look compatible to me.....   :P
Own/Love: REɅLFORCE 87UB EK Edition 45g
Have owned/used: Realforce 103-UB, XArmor U9BL, Filco Majestouch 104-key with Cherry MX Blues, Browns, and Reds, Steelseries 6gv2, Leopold with Browns
Offline hfcobra
« Reply #10 on: Sat, 13 November 2010, 01:50:26 »
Quote from: ripster;246222
The only reason I know this is because of my Apple M0110.  It's those old linear ALPS.
Now these cause a slightly DIFFERENT problem.  It's the thickness of the stems.
ah, i see now.   I did not think that that would have been a big issue, but now that you have put close ups of the keys i can see that that would definitely be a problem
