Author Topic: Creamy Fullsize Keyboard Recommendations  (Read 3387 times)
Offline Jalberstone
« on: Mon, 21 September 2026, 17:25:10 »
Hi Everyone!
I used to be very into the mechanical keyboard community many years ago, and I am getting back into it now that I have a need for a new fullsize keyboard (with numberpad) for work. There have been a lot of new switches and technologies since I was active in the community, so I'm hoping a few of you can give me some guidance for what I'm looking for.
I'm looking for a high-quality fullsize keyboard with creamy sounding switches. I'm used to Cherry MX Browns, so would prefer a similar sort of tactile switch. Bonus points if the keyboard has a volume knob, the switches are hotswappable, and has very nice/high-quality keycaps. I don't care about RGB or overall looks, as long as it looks appropriate for an office environment.
For context, I currently use a Ducky One 2 with MX Browns for work and a Keychron Q6 with MX Browns. I love my Ducky, and am overall looking for an upgrade. My Keychron is okay, but would love something with more of a creamy/thocky sound instead of clacky. The metal case is a bit heavy too, but I would get another board also made out of metal if everything else is what I'm looking for.
I'm willing to pay a premium for the right board (think $150-$200, or more if needed). Top priorities are the creamy sound of the switches on a fullsize keyboard. Please let me know what your thoughts are. Thanks!
TL;DR: Looking for a fullsize keyboard with creamy sounding switches being the most important factor. Money is not really an object. Do you have any recommendations from any manufacturer, or should I look into building my own?
Offline keebadict
Re: Creamy Fullsize Keyboard Recommendations
« Reply #1 on: Wed, 23 September 2026, 09:14:01 »
Hello !
For creamy tactile you can check Bsun switches, I have noticed their recent tactile switches are creamy.
For thew full size, if you like something with premium feel and look you can go with Qk100 Mk2, Qk102. Neo98
If plastic is ok, an Aula will do.
I highly recommend an aluminum board with brass or copper weight for long lasting satisfaction.
Offline bitternoyster
    • fnaf
« Reply #2 on: Mon, 28 September 2026, 21:06:38 »
Cool! Would love to have a Creamy Fullsize keyboard.
