Author Topic: Need to glue together a keyboard parts  (Read 2228 times)
Offline codek
« on: Fri, 12 November 2010, 19:37:25 »
I need a good compound to glue together plastic ibm model m parts that broke off.
Recommend some please.
Offline msiegel
« Reply #1 on: Fri, 12 November 2010, 19:39:20 »
which parts broke?
Offline codek
« Reply #2 on: Sat, 13 November 2010, 01:36:39 »
Quote from: ripster;246165
Here is the best stuff.  Used it to repair a Industrial M13 broken in transit.
same thing happened to me.  There is crack on bottom corner of my keyboard.  Thank God I found the piece inside.  Also the left mount broke off so I have to epoxy it on.
This all happened even though the keyboard was well packed.  It's gotta be the weight.
Thanks Ripster, you are a keyboard Genius!
« Reply #3 on: Sat, 13 November 2010, 06:55:43 »
Make sure that you get the "plastic repair" epoxy, and not just any epoxy. The right type should have some kind (or several kinds) of solvent in them that will penetrate the plastic and cause chemical bonds to form when it dries away.
Offline codek
« Reply #4 on: Sat, 13 November 2010, 17:29:27 »
Quote from: Findecanor;246264
thanks for the heads up!
