Author Topic: Why does the spacebar on my new unicomp keyboard have a stabilizer bar*?  (Read 3028 times)
Offline sam113101
It doesn't even stabilize it. The keys wobble much.
Hoping to hear from you again, your dearest friend, sam113101.
Offline hfcobra
« Reply #1 on: Fri, 12 November 2010, 23:33:56 »
so that if you press it on one side then the switch in the center still works and registers a key press.   My stabilizer bar on my Dell Quiet Key from a while back broke and now the space bar cannot work unless i press it perfectly in the center.
Own/Love: REɅLFORCE 87UB EK Edition 45g
Have owned/used: Realforce 103-UB, XArmor U9BL, Filco Majestouch 104-key with Cherry MX Blues, Browns, and Reds, Steelseries 6gv2, Leopold with Browns
Offline codek
« Reply #2 on: Sat, 13 November 2010, 01:34:44 »
are these stabilizer bars on most model m's?
Offline MissileMike
« Reply #3 on: Sat, 13 November 2010, 07:49:02 »
Quote from: codek;246230
As far as I know, they're on all M space bars- never seen one w/o it.  Now on older Ms, the numpad enter and + keys have stabilizers too.  But that seemed to go away around 1987.  Someone else here could say for sure.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #4 on: Sat, 13 November 2010, 15:03:19 »
It's not like the newer Ms wouldn't have anything stabilizing there - the funny colored inserts serve the same purpose and generally don't do a much worse job (well, unless you got a problem with loose rivets...).
Oh, the key stems on MX switches wobble quite a bit, too - but as in case of the BS boards, this doesn't affect function negatively, so noone cares. Key wobble might be a half-decent quality indicator on rubber dome boards. I think it's only the combination with increased friction that makes this critical.
