Author Topic: [GB]Space66% Spaceforge  (Read 181 times)
Offline AIRPOTTER
  • Owner of Gray Studio
« on: Thu, 08 October 2026, 22:48:20 »
GB Start:   7 PM, Oct. 8th, EDT.
GB End: 7 PM, Oct. 30th, EDT.
Notin Links:https://graystudio.notion.site/Space66-Spaceforge-3d26fb6467f2805c8274ef014fae5fb9?source=copy_link
Links:https://graystudio.club/products/gbspace66-spaceforge
Board Details
Case Material: The case is made of 6063 custom-CNC aluminum with the surface option of anodization or Powder-coating treatment
Front Height:19.00mm
Typing Angle: 7°
Mounting:  Gasket or Top mount
PCB: 1.6mm Hot Swap PCB . No Flex cuts. ESD protection.  VIAL support out of box.
Layout Fixed layout, with stepped Caps Lock support
Photos
Accessories: https://imgur.com/a/n4hdrKZ
Quicksilver: https://imgur.com/a/gFiH0J1
Titanium: https://imgur.com/a/xnTt1RF
Deep Grey: https://imgur.com/a/ohqvXin
Darth Vader:https://imgur.com/a/WGTmO6W
Papaya:https://imgur.com/a/L3MsEXI
Modena:https://imgur.com/a/JZwC5jI
White Sparkle:https://imgur.com/a/PFeLBup
Vintage:https://imgur.com/a/TuIkErg
Media
Titanium-alexotos:
Jinju진주-Vintage:
Quicksilver-Bobby:https://www.bilibili.com/video/BV1wftm6jEqZ/?share_source=copy_web&vd_source=39c526478ae7dc47f8ab7153b4b092db
Papaya-浮生半盏茶:https://www.bilibili.com/video/BV1Kytu6GENq/?share_source=copy_web&vd_source=39c526478ae7dc47f8ab7153b4b092db
Modena-闲人怪怪:https://www.bilibili.com/video/BV1Hst66xExH/?share_source=copy_web&vd_source=39c526478ae7dc47f8ab7153b4b092db
Contents
[1x Space66% Spaceforge Package Includes all the following]:
1x Case (top case, bottom case, weight frame, weight, front badge, USB Port Badge)
1x LED diffuser
1x Knob
1x Plate
Required Screws
1x PCB (1.6mm,Non-flex-cuts,Hot-swap,Vial)
1x Set of Consi Studio PCB-Mount Stabilizers V3
2x Sets of Gasket Nails (50A & 70A, 10 pcs each)
1x Set of Hotswap PCB locator (6 pcs)
1x Top Mount Screws with Shims
1x Set of Case Rubber Feet (6 pcs)
1x Updated screwdriver (Graystudio brand)
1x tweezer (Always test the PCB before assembly!)
Extra Screws
Designer packaging (w/ Carrying Case)
FAQ
What does blind box mean?
Blind box refers to colors other than the 8 currently displayed, and the case  may be anodized or spray coat.
Is the Spaceforge hot-swappable?
Yes. It`s wired 1.6 mm Hot-swap PCB with no flex cuts.
What plates  are available?
FR4(1.5mm), Alu(1.5mm),PC(4mm), PEI(4mm) and Peek(4mm) .
VIAL or VIA?
The default firmware for Spaceforge is VIAL,but  VIA documents will be provided around fulfillment.
What foam is included?
1.5mm Plate(FR4/Alu) : 3.5 mm Poron plate foam & 0.5 mm ixPE PCB foam.
4mm Plate(PC/PEI/PEEK) : 0.5 mm ixPE PCB foam.
Why are PEI and PEEK plates more expensive?
Because these two materials have higher raw material costs, although the processing is the same as PC, the final cost is also higher.
Re: [GB]Space66% Spaceforge
« Reply #1 on: Tue, 13 October 2026, 11:21:41 »
Approved! :thumb:
